Update a SAML service provider configuration
Updates the configuration for a SAML service provider. Use this endpoint to modify existing settings for authentication integration.
HTTP method and endpoint
PATCH /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Usage notes
Updates a SAML service provider configuration.
Request Body
| Name | Type | Description |
enabled |
boolean |
The SAML service provider is enabled. Valid for PATCH and GET operations only. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12320791 |
SAML can only be disabled using the console or a SAML-authenticated application. |
href |
string |
_links
certificate
security_saml_sp
enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
