REST API reference
Update an SAML service provider configuration
Updates a SAML service provider configuration to modify its settings according to your requirements.
HTTP method and endpoint
PATCH /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Request Body
Name Type Description
enabled
boolean
The SAML service provider is enabled. Valid for PATCH and GET operations only.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
12320791
SAML can only be disabled using the console or a SAML-authenticated application.
string
certificate
security_saml_sp
enabled
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
