REST API reference
Update a SAML service provider configuration
Updates a SAML service provider configuration to modify its settings or attributes. This action is typically used when you need to change authentication or identity provider details in your environment.
HTTP method and endpoint
PATCH /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Request Body
Name Type Description
enabled
boolean
The SAML service provider is enabled. Valid for PATCH and GET operations only.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
12320791
SAML can only be disabled using the console or a SAML-authenticated application.
string
certificate
security_saml_sp
enabled
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
