REST API reference
Updates the ssh server setting for a cluster
  • key_exchange_algorithms - ssh key exchange algorithms
  • mac_algorithms - mac algorithms
  • max_authentication_retry_count - maximum authentication retries allowed before closing the connection
  • connections_per_second - maximum allowed connections per second
  • max_instances - maximum allowed connections per node
  • per_source_limit - maximum allowed connections from the same client host # related ontap commands
  • security ssh
  • security protocol ssh
PATCH /security/ssh
Introduced In: 9.7
Updates the SSH server setting for a cluster.
Optional parameters
  • ciphers - Encryption algorithms for the payload
  • key_exchange_algorithms - SSH key exchange algorithms
  • mac_algorithms - MAC algorithms
  • max_authentication_retry_count - Maximum authentication retries allowed before closing the connection
  • connections_per_second - Maximum allowed connections per second
  • max_instances - Maximum allowed connections per node
  • per_source_limit - Maximum allowed connections from the same client host
  • security ssh
Request Body
Name Type Description
ciphers
array[string]
Ciphers for encrypting the data.
integer
Maximum connections allowed per second.
array[string]
Key exchange algorithms.
mac_algorithms
array[string]
MAC algorithms.
integer
Maximum authentication retries allowed before closing the connection.
max_instances
integer
Maximum possible simultaneous connections.
per_source_limit
integer
Maximum connections from the same client host.
Example request
  "ciphers": [
    "aes256_ctr",
    "aes192_ctr",
    "aes128_ctr"
  "key_exchange_algorithms": [
    "diffie_hellman_group_exchange_sha256",
    "diffie_hellman_group14_sha1"
  "mac_algorithms": [
    "hmac_sha1",
    "hmac_sha2_512_etm"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10682372
There must be at least one key exchange algorithm associated with the SSH configuration.
10682373
There must be at least one cipher associated with the SSH configuration.
10682375
Failed to modify SSH key exchange algorithms.
10682378
Failed to modify SSH ciphers.
10682399
Key exchange algorithm not supported in FIPS enabled mode.
10682400
Failed to modify SSH MAC algorithms.
10682401
MAC algorithm not supported in FIPS enabled mode.
10682403
There must be at least one MAC algorithm with the SSH configuration.
10682413
Failed to modify maximum authentication retry attempts.
10682413
10682418
Cipher not supported in FIPS enabled mode.
string
cluster_ssh_server
ciphers
array[string]
integer
array[string]
mac_algorithms
array[string]
MAC algorithms.
integer
max_instances
integer
per_source_limit
integer
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
