Updates the ssh server setting for a cluster
key_exchange_algorithms- ssh key exchange algorithms -
mac_algorithms- mac algorithms -
max_authentication_retry_count- maximum authentication retries allowed before closing the connection -
connections_per_second- maximum allowed connections per second -
max_instances- maximum allowed connections per node -
per_source_limit- maximum allowed connections from the same client host # related ontap commands -
security ssh -
security protocol ssh
PATCH /security/ssh
Introduced In: 9.7
Updates the SSH server setting for a cluster.
Optional parameters
ciphers- Encryption algorithms for the payload -
key_exchange_algorithms- SSH key exchange algorithms -
mac_algorithms- MAC algorithms -
max_authentication_retry_count- Maximum authentication retries allowed before closing the connection -
connections_per_second- Maximum allowed connections per second -
max_instances- Maximum allowed connections per node -
per_source_limit- Maximum allowed connections from the same client host
Related ONTAP commands
security ssh -
Request Body
| Name | Type | Description |
_links |
ciphers |
array[string] |
Ciphers for encrypting the data. |
connections_per_second |
integer |
Maximum connections allowed per second. |
key_exchange_algorithms |
array[string] |
Key exchange algorithms. |
mac_algorithms |
array[string] |
MAC algorithms. |
max_authentication_retry_count |
integer |
Maximum authentication retries allowed before closing the connection. |
max_instances |
integer |
Maximum possible simultaneous connections. |
per_source_limit |
integer |
Maximum connections from the same client host. |
Example request
"ciphers": [
"aes256_ctr",
"aes192_ctr",
"aes128_ctr"
"key_exchange_algorithms": [
"diffie_hellman_group_exchange_sha256",
"diffie_hellman_group14_sha1"
"mac_algorithms": [
"hmac_sha1",
"hmac_sha2_512_etm"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10682372 |
There must be at least one key exchange algorithm associated with the SSH configuration. |
10682373 |
There must be at least one cipher associated with the SSH configuration. |
10682375 |
Failed to modify SSH key exchange algorithms. |
10682378 |
Failed to modify SSH ciphers. |
10682399 |
Key exchange algorithm not supported in FIPS enabled mode. |
10682400 |
Failed to modify SSH MAC algorithms. |
10682401 |
MAC algorithm not supported in FIPS enabled mode. |
10682403 |
There must be at least one MAC algorithm with the SSH configuration. |
10682413 |
Failed to modify maximum authentication retry attempts. |
10682413 |
10682418 |
Cipher not supported in FIPS enabled mode. |
href |
string |
_links
cluster_ssh_server
_links |
ciphers |
array[string] |
integer |
array[string] |
mac_algorithms |
array[string] |
MAC algorithms. |
integer |
max_instances |
integer |
per_source_limit |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
