Update the SSH server setting for a cluster
PATCH /security/ssh
Introduced In: 9.7
Updates the SSH server setting for a cluster.
Optional parameters
ciphers- Encryption algorithms for the payload -
key_exchange_algorithms- SSH key exchange algorithms -
mac_algorithms- MAC algorithms -
host_key_algorithms- Host key algorithms -
max_authentication_retry_count- Maximum authentication retries allowed before closing the connection -
connections_per_second- Maximum allowed connections per second -
max_instances- Maximum allowed connections per node -
is_rsa_in_publickey_algorithms_enabled- ssh-rsa enabled status for public key algorithms -
per_source_limit- Maximum allowed connections from the same client host
Related ONTAP commands
security ssh -
security protocol ssh
Request Body
| Name | Type | Description |
ciphers |
array[string] |
Ciphers for encrypting the data. |
connections_per_second |
integer |
Maximum connections allowed per second. |
host_key_algorithms |
array[string] |
Host key algorithms. The host key algorithm 'ssh_ed25519' can be configured only in non-FIPS mode. |
is_rsa_in_publickey_algorithms_enabled |
boolean |
Enables or disables the ssh-rsa signature scheme, which uses the SHA-1 hash algorithm, for RSA keys in public key algorithms. If this flag is false, older SSH implementations might fail to authenticate using RSA keys. This flag should be enabled only as a temporary measure until legacy SSH client implementations can be upgraded or reconfigured with another key type, for example: ECDSA. |
key_exchange_algorithms |
array[string] |
Key exchange algorithms. |
mac_algorithms |
array[string] |
MAC algorithms. |
max_authentication_retry_count |
integer |
Maximum authentication retries allowed before closing the connection. |
max_instances |
integer |
Maximum possible simultaneous connections. |
per_source_limit |
integer |
Maximum connections from the same client host. |
Example request
"ciphers": [
"aes256_ctr",
"aes192_ctr",
"aes128_ctr"
"host_key_algorithms": [
"ecdsa_sha2_nistp256",
"ssh_rsa"
"key_exchange_algorithms": [
"diffie_hellman_group_exchange_sha256",
"ecdh_sha2_nistp256",
"diffie_hellman_group18_sha512"
"mac_algorithms": [
"hmac_sha2_512",
"hmac_sha2_512_etm"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
10682372 |
There must be at least one key exchange algorithm associated with the SSH configuration. |
10682373 |
There must be at least one cipher associated with the SSH configuration. |
10682375 |
Failed to modify SSH key exchange algorithms. |
10682378 |
Failed to modify SSH ciphers. |
10682399 |
Key exchange algorithm not supported in FIPS enabled mode. |
10682400 |
Failed to modify SSH MAC algorithms. |
10682401 |
MAC algorithm not supported in FIPS enabled mode. |
10682403 |
There must be at least one MAC algorithm with the SSH configuration. |
10682413 |
Failed to modify maximum authentication retry attempts. |
10682413 |
10682418 |
Cipher not supported in FIPS enabled mode. |
10682423 |
There must be at least one host key algorithm associated with the SSH configuration. |
10682424 |
Host key algorithm not supported in FIPS enabled mode. |
10682425 |
Failed to modify Host key algorithms. |
10682426 |
Failed to modify ssh-rsa enabled status for publickey algorithms configuration. |
10682428 |
10682429 |
Adding 'diffie_hellman_group16_sha512' or 'diffie_hellman_group18_sha512' to the SSH key exchange algorithms list requires an effective cluster version of ONTAP 9.16.1 or later. |
href |
string |
_links
cluster_ssh_server
ciphers |
array[string] |
integer |
array[string] |
boolean |
array[string] |
mac_algorithms |
array[string] |
MAC algorithms. |
integer |
max_instances |
integer |
per_source_limit |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
