REST API reference
Update the SSH server setting for a cluster
PATCH /security/ssh
Introduced In: 9.7
Updates the SSH server setting for a cluster.
Optional parameters
  • ciphers - Encryption algorithms for the payload
  • key_exchange_algorithms - SSH key exchange algorithms
  • mac_algorithms - MAC algorithms
  • host_key_algorithms - Host key algorithms
  • max_authentication_retry_count - Maximum authentication retries allowed before closing the connection
  • connections_per_second - Maximum allowed connections per second
  • max_instances - Maximum allowed connections per node
  • is_rsa_in_publickey_algorithms_enabled - ssh-rsa enabled status for public key algorithms
  • per_source_limit - Maximum allowed connections from the same client host
  • security ssh
  • security protocol ssh
Request Body
Name Type Description
ciphers
array[string]
Ciphers for encrypting the data.
integer
Maximum connections allowed per second.
host_key_algorithms
array[string]
Host key algorithms. The host key algorithm 'ssh_ed25519' can be configured only in non-FIPS mode.
boolean
Enables or disables the ssh-rsa signature scheme, which uses the SHA-1 hash algorithm, for RSA keys in public key algorithms. If this flag is false, older SSH implementations might fail to authenticate using RSA keys. This flag should be enabled only as a temporary measure until legacy SSH client implementations can be upgraded or reconfigured with another key type, for example: ECDSA.
array[string]
Key exchange algorithms.
mac_algorithms
array[string]
MAC algorithms.
integer
Maximum authentication retries allowed before closing the connection.
max_instances
integer
Maximum possible simultaneous connections.
per_source_limit
integer
Maximum connections from the same client host.
Example request
  "ciphers": [
    "aes256_ctr",
    "aes192_ctr",
    "aes128_ctr"
  "host_key_algorithms": [
    "ecdsa_sha2_nistp256",
    "ssh_rsa"
  "key_exchange_algorithms": [
    "diffie_hellman_group_exchange_sha256",
    "ecdh_sha2_nistp256",
    "diffie_hellman_group18_sha512"
  "mac_algorithms": [
    "hmac_sha2_512",
    "hmac_sha2_512_etm"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
10682372
There must be at least one key exchange algorithm associated with the SSH configuration.
10682373
There must be at least one cipher associated with the SSH configuration.
10682375
Failed to modify SSH key exchange algorithms.
10682378
Failed to modify SSH ciphers.
10682399
Key exchange algorithm not supported in FIPS enabled mode.
10682400
Failed to modify SSH MAC algorithms.
10682401
MAC algorithm not supported in FIPS enabled mode.
10682403
There must be at least one MAC algorithm with the SSH configuration.
10682413
Failed to modify maximum authentication retry attempts.
10682413
10682418
Cipher not supported in FIPS enabled mode.
10682423
There must be at least one host key algorithm associated with the SSH configuration.
10682424
Host key algorithm not supported in FIPS enabled mode.
10682425
Failed to modify Host key algorithms.
10682426
Failed to modify ssh-rsa enabled status for publickey algorithms configuration.
10682428
10682429
Adding 'diffie_hellman_group16_sha512' or 'diffie_hellman_group18_sha512' to the SSH key exchange algorithms list requires an effective cluster version of ONTAP 9.16.1 or later.
string
cluster_ssh_server
ciphers
array[string]
integer
host_key_algorithms
array[string]
boolean
array[string]
mac_algorithms
array[string]
MAC algorithms.
integer
max_instances
integer
per_source_limit
integer
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
