Update an aggregate specified by the UUID
Updates the properties of a specific aggregate using its UUID. This operation initiates a job and provides a link to track its progress.
HTTP method and endpoint
PATCH /storage/aggregates/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates the aggregate specified by the UUID with the properties in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate add-disks -
storage aggregate mirror -
storage aggregate modify -
storage aggregate relocation start -
storage aggregate rename
uuid |
string |
path |
True |
Aggregate UUID |
auto_provision_policy |
string |
query |
False |
If set to expand, the PATCH operation runs the recommended expansion of the aggregate.
simulate |
boolean |
query |
False |
If set to true, the PATCH operation runs a simulated aggregate expansion with the provided input disk count and returns the proposed size of the new aggregate along with any associated warnings.
disk_size |
integer |
query |
False |
If set, PATCH only selects disks of the specified size. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
block_storage |
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier. |
cloud_storage |
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier. |
create_time |
string |
Timestamp of aggregate creation. |
data_encryption |
dr_home_node |
Node where the aggregate resides after disaster recovery. The value for this field might differ from the 'node' field during switchover. |
home_node |
Node where the aggregate resides after giveback. The value for this field might differ from the value of the 'node' field during takeover. |
inactive_data_reporting |
name |
string |
Aggregate name. |
node |
Node where the aggregate currently resides. |
recommendation_spares |
array[aggregate_spare] |
Information on the aggregate's remaining hot spare disks. |
snapshot |
space |
state |
string |
Operational state of the aggregate. |
uuid |
string |
Aggregate UUID. |
Example request
"block_storage": {
"hybrid_cache": {
"disk_count": 6,
"raid_type": "string",
"size": 1612709888,
"used": 26501122
"mirror": {
"enabled": "",
"state": "string"
"plexes": [
"name": "plex0"
"primary": {
"disk_count": 8,
"disk_type": "string",
"raid_size": 16,
"simulated_raid_groups": [
"name": "string",
"cloud_storage": {
"stores": [
"cloud_store": {
"name": "store1",
"used": 0
"create_time": "2018-01-01T12:00:00-04:00",
"dr_home_node": {
"name": "node1",
"home_node": {
"name": "node1",
"inactive_data_reporting": {
"start_time": "2019-12-12T12:00:00-04:00"
"name": "node1_aggr_1",
"node": {
"name": "node1",
"recommendation_spares": [
"checksum_style": "string",
"disk_class": "solid_state",
"is_partition": 1,
"layout_requirements": [
"aggregate_min_disks": 6,
"raid_group": {
"default": 16,
"max": 28,
"min": 5
"node": {
"name": "node1",
"size": 10156769280,
"syncmirror_pool": "string",
"usable": 9
"snapshot": {
"files_total": 10,
"files_used": 3,
"max_files_available": 5,
"max_files_used": 50
"space": {
"block_storage": {
"aggregate_metadata": 2655,
"aggregate_metadata_percent": 8,
"available": 10156560384,
"data_compacted_count": 1990000,
"data_compaction_space_saved": 1996000,
"data_compaction_space_saved_percent": 27,
"full_threshold_percent": 0,
"inactive_user_data": 304448,
"inactive_user_data_percent": 0,
"physical_used": 2461696,
"physical_used_percent": 50,
"used": 2088960,
"used_including_snapshot_reserve": 674685,
"used_including_snapshot_reserve_percent": 35,
"volume_deduplication_shared_count": 1990000,
"volume_deduplication_space_saved": 1996000,
"volume_deduplication_space_saved_percent": 27,
"volume_footprints_percent": 14
"cloud_storage": {
"used": 402743264
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots_flexclones": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"footprint": 608896,
"snapshot": {
"available": 2000,
"reserve_percent": 20,
"total": 5000,
"used": 3000,
"used_percent": 45
"state": "string",
"uuid": "string"
Status: 202, Accepted
job |
num_records |
integer |
Number of records |
records |
array[aggregate] |
warnings |
array[aggregate_warning] |
List of validation warnings and remediation advice for the aggregate simulate behavior. |
"job": {
"uuid": "string"
"records": [
"block_storage": {
"hybrid_cache": {
"disk_count": 6,
"size": 1612709888,
"used": 26501122
"mirror": {
"enabled": "",
"state": "string"
"plexes": [
"name": "plex0"
"primary": {
"disk_count": 8,
"raid_size": 16,
"name": "string",
"cloud_storage": {
"stores": [
"cloud_store": {
"name": "store1",
"used": 0
"dr_home_node": {
"name": "node1",
"home_node": {
"name": "node1",
"node": {
"name": "node1",
"is_partition": 1,
"raid_group": {
"default": 16,
"max": 28,
"min": 5
"node": {
"name": "node1",
"usable": 9
"snapshot": {
"files_total": 10,
"files_used": 3,
"space": {
"block_storage": {
"used": 2088960,
"cloud_storage": {
"used": 402743264
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
"snapshot": {
"available": 2000,
"total": 5000,
"used": 3000,
"used_percent": 45
"state": "string",
"uuid": "string"
"warnings": [
"action": {
"arguments": [
"string"
"message": "string"
"name": "string",
"warning": {
"arguments": [
"string"
"message": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262247 |
The value is invalid for the field. |
460777 |
Failed to get information on the job. |
786434 |
Cannot connect to node where the aggregate resides. |
786435 |
Internal Error. Failed to create a communication handle. |
786439 |
An aggregate already uses the specified name. |
786447 |
Failed to modify the aggregate. |
786456 |
Failed to add disks to the aggregate. |
786458 |
Failed to rename aggregate. |
786468 |
VLDB is offline. |
786472 |
Node that hosts the aggregate is offline. |
786479 |
Cannot find node ID for the node. |
786491 |
Not enough spares on the node. |
786730 |
Internal Error |
786771 |
Aggregate does not exist. |
786787 |
Aggregate is not online. |
786808 |
Aggregate mirror failed. |
786867 |
Specified aggregate resides on the remote cluster. |
786911 |
Not every node in the cluster has the Data ONTAP version required for the feature. |
786923 |
This operation is not allowed during the pre-commit phase of a 7-mode to clustered Data ONTAP transition. |
786924 |
Internal error for an aggregate that is in the pre-commit phase of a 7-mode to clustered Data ONTAP transition. |
786955 |
Modifying raidtype to raid_tec requires a minimum of six disks in the RAID Group. |
786956 |
Modifying raidtype to raid_dp requires a minimum of four disks in the RAID Group. |
786965 |
Spare Selection in userspace failed. |
787046 |
Mirroring of a FabricPool is not allowed. |
787092 |
The target field cannot be specified for this operation. |
787144 |
Aggregate is not a FabricPool. |
787156 |
Modifying the attributes of mirror object store is not allowed. |
787169 |
Only one field can be modified per operation. |
787170 |
Failed to patch the "block_storage.primary.disk_count" because the disk count specified is smaller than existing disk count. |
787172 |
This query is only allowed during the modification of the specified field. |
787178 |
Unmirroring an aggregate with a PATCH operation is not supported. |
787187 |
Internal error. Failed to check if the aggregate is a FabricPool. |
1258699 |
Cannot use all the disks specified for the requested operation. |
1263500 |
Operation will lead to creation of new raid group. |
1263501 |
Operation will exceed half of the maximum volume sizes allowed on the node. |
1263502 |
One spare data partition from at least one of the chosen root-data1-data2 disks will not be used. |
1263503 |
Operation will lead to downsizing of one or more disks. |
1263504 |
Operation will lead to a spares low condition. |
1263598 |
One or more selected disks will be partitioned. |
1263624 |
Operation will lead to a no sparecore condition. |
2425736 |
No matching node found for the UUID provided. |
7209049 |
Cannot perform the operation because the aggregate is currently expanding. |
7209075 |
Cannot perform the operation because the volume size limit for this system type would be exceeded. |
13108106 |
Cannot run aggregate relocation because volume expand is in progress. |
19726347 |
There are a number of unassigned disks visible to the node that owns this aggregate. |
19726382 |
Another provisioning operation is in progress on this cluster. Wait a few minutes, and try the operation again. |
19726390 |
Unable to automatically expand this aggregate. |
19726391 |
Too many unassigned disks visible to the node that owns this aggregate. |
19726392 |
Layout of this aggregate is not a supported configuration. |
19726393 |
Failed to expand the aggregate. Aggregate expansion is not supported on this system. |
19726394 |
Automatic aggregate expansion is not supported on systems with multiple data aggregates. |
19726395 |
Automatic aggregate expansion is not supported when MetroCluster is not configured. |
19726396 |
Automatic aggregate expansion is not supported when the DR group is not in a normal state. |
19726397 |
Aggregates must contain disks with identical disk-types and disk-sizes. |
19726402 |
Internal error. Unable to determine the MetroCluster configuration state. |
19726538 |
Cannot perform the operation because the aggregate is not in a healthy state. |
26542083 |
Destination node is at higher Data ONTAP version than source node. |
26542084 |
Source node is at higher Data ONTAP version than destination node. |
26542097 |
Unable to get D-blade ID of destination. |
26542101 |
Unable to contact the source node. |
26542102 |
Unable to contact the destination node. |
26542120 |
An SVM migrate operation is in progress. When the migrate operation completes, try the operation again. |
26542121 |
A MetroCluster disaster recovery operation is in progress. When the recovery operation completes, try the operation again. |
196608334 |
Failed to modify the aggregate because it contains NAE volumes. |
196608335 |
Failed to modify the aggregate because it contains non-encrypted volumes. |
href |
string |
_links
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count |
integer |
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
enabled |
boolean |
Specifies whether the aggregate uses HDDs with SSDs as a cache. |
raid_type |
string |
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
size |
integer |
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
used |
integer |
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
mirror
enabled |
boolean |
Aggregate is SyncMirror protected |
state |
string |
plex_reference
Plex
name |
string |
data_disk_count |
integer |
Number of data disks in RAID group. |
is_partition |
boolean |
Indicates whether the disk is partitioned (true) or whole (false). |
name |
string |
Name of the raid group. |
parity_disk_count |
integer |
Number of parity disks in RAID group. |
raid_type |
string |
RAID type of the aggregate. |
usable_size |
integer |
Usable size of each disk, in bytes. |
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
disk_count |
integer |
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache. |
disk_type |
string |
The type of disk being used by the aggregate. |
raid_size |
integer |
Option to specify the maximum number of disks that can be included in a RAID group. |
raid_type |
string |
simulated_raid_groups |
array[simulated_raid_groups] |
block_storage
hybrid_cache |
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs. |
mirror |
plexes |
array[plex_reference] |
Plex reference for each plex in the aggregate. |
primary |
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details. |
cloud_store
Cloud store
name |
string |
uuid |
string |
cloud_storage_tier
cloud_store |
Cloud store |
used |
integer |
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes. |
cloud_storage
attach_eligible |
boolean |
Specifies whether the aggregate is eligible for a cloud store to be attached. |
stores |
array[cloud_storage_tier] |
Configuration information for each cloud storage portion of the aggregate. |
tiering_fullness_threshold |
integer |
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations. |
data_encryption
drive_protection_enabled |
boolean |
Specifies whether the aggregate uses self-encrypting drives with data protection enabled. |
software_encryption_enabled |
boolean |
Specifies whether NetApp aggregate encryption is enabled. All data in the aggregate is encrypted. |
dr_home_node
name |
string |
uuid |
string |
home_node
name |
string |
uuid |
string |
enabled |
boolean |
Specifes whether or not inactive data reporting is enabled on the aggregate. |
start_time |
string |
Timestamp at which inactive data reporting was enabled on the aggregate. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Peformance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
metric
The most recent sample of I/O metrics for the aggregate.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
node
name |
string |
uuid |
string |
raid_group
default |
integer |
Default number of disks in a RAID group. |
max |
integer |
Maximum number of disks allowed in a RAID group. |
min |
integer |
Minimum number of disks allowed in a RAID group. |
layout_requirement
aggregate_min_disks |
integer |
Minimum number of disks to create an aggregate. |
default |
boolean |
Indicates if this RAID type is the default. |
raid_group |
raid_type |
string |
RAID type. |
node
Node where the spares are assigned.
name |
string |
uuid |
string |
aggregate_spare
checksum_style |
string |
The checksum type that has been assigned to the spares. |
disk_class |
string |
Disk class of spares. |
disk_type |
string |
Type of disk. |
is_partition |
boolean |
Indicates whether a disk is partitioned (true) or whole (false) |
layout_requirements |
array[layout_requirement] |
Available RAID protections and their restrictions. |
node |
Node where the spares are assigned. |
size |
integer |
Usable size of each spare, in bytes. |
syncmirror_pool |
string |
SyncMirror spare pool. |
usable |
integer |
Total number of usable spares in the bucket. The usable count for each class of spares does not include reserved spare capacity recommended by ONTAP best practices.
snapshot
files_total |
integer |
Total files allowed in Snapshot copies |
files_used |
integer |
Total files created in Snapshot copies |
max_files_available |
integer |
Maximum files available for Snapshot copies |
max_files_used |
integer |
Files in use by Snapshot copies |
block_storage
aggregate_metadata |
integer |
Space used by different metafiles and internal operations inside the aggregate, in bytes. |
aggregate_metadata_percent |
integer |
Aggregate metadata as a percentage. |
available |
integer |
Space available in bytes. |
data_compacted_count |
integer |
Amount of compacted data in bytes. |
data_compaction_space_saved |
integer |
Space saved in bytes by compacting the data. |
data_compaction_space_saved_percent |
integer |
Percentage saved by compacting the data. |
full_threshold_percent |
integer |
The aggregate used percentage at which 'monitor.volume.full' EMS is generated. |
inactive_user_data |
integer |
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **. |
inactive_user_data_percent |
integer |
The percentage of inactive user data in the block storage. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data_percent or **. |
physical_used |
integer |
Total physical used size of an aggregate in bytes. |
physical_used_percent |
integer |
Physical used percentage. |
size |
integer |
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve. |
used |
integer |
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata. |
used_including_snapshot_reserve |
integer |
Total used including the Snapshot copy reserve, in bytes. |
used_including_snapshot_reserve_percent |
integer |
Total used including the Snapshot reserve as a percentage. |
volume_deduplication_shared_count |
integer |
Amount of shared bytes counted by storage efficiency. |
volume_deduplication_space_saved |
integer |
Amount of space saved in bytes by storage efficiency. |
volume_deduplication_space_saved_percent |
integer |
Percentage of space saved by storage efficiency. |
volume_footprints_percent |
integer |
A summation of volume footprints inside the aggregate, as a percentage. A volume's footprint is the amount of space being used for the volume in the aggregate. |
cloud_storage
used |
integer |
Used space in bytes in the cloud store. Only applicable for aggregates with a cloud store tier. |
efficiency
Storage efficiency.
logical_used |
integer |
Logical used |
ratio |
number |
Data reduction ratio (logical_used / used) |
savings |
integer |
Space saved by storage efficiencies (logical_used - used) |
Storage efficiency that does not include the savings provided by Snapshot copies.
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
Storage efficiency that does not include the savings provided by Snapshot copies and Flexclone volumes.
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
snapshot
available |
integer |
Available space for Snapshot copies in bytes |
reserve_percent |
integer |
Percentage of space reserved for Snapshot copies |
total |
integer |
Total space for Snapshot copies in bytes |
used |
integer |
Space used by Snapshot copies in bytes |
used_percent |
integer |
Percentage of disk space used by Snapshot copies |
space
block_storage |
cloud_storage |
efficiency |
Storage efficiency. |
efficiency_without_snapshots |
Storage efficiency that does not include the savings provided by Snapshot copies. |
efficiency_without_snapshots_flexclones |
Storage efficiency that does not include the savings provided by Snapshot copies and Flexclone volumes. |
footprint |
integer |
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
snapshot |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
The real time I/O statistics for the aggregate.
iops_raw |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
throughput_raw |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
aggregate
block_storage |
cloud_storage |
create_time |
string |
data_encryption |
dr_home_node |
home_node |
name |
string |
Aggregate name. |
node |
snapshot |
space |
state |
string |
uuid |
string |
Aggregate UUID. |
job_link
uuid |
string |
action
arguments |
array[string] |
Arguments present in the specified action message. |
code |
integer |
Corrective action code of the specified action. |
message |
string |
Specifies the corrective action to be taken to resolve the issue. |
warning
arguments |
array[string] |
Arguments present in the warning message encountered. |
code |
integer |
Warning code of the warning encountered. |
message |
string |
Details of the warning encountered by the aggregate simulate query. |
aggregate_warning
action |
name |
string |
Name of the entity that returns the warning. |
warning |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
