REST API reference
Update an aggregate specified by the UUID
Updates the specified aggregate with new properties, initiating a job and providing a link to track its progress.
HTTP method and endpoint
PATCH /storage/aggregates/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates the aggregate specified by the UUID with the properties in the body. This request starts a job and returns a link to that job.
  • storage aggregate add-disks
  • storage aggregate mirror
  • storage aggregate modify
  • storage aggregate relocation start
  • storage aggregate rename
uuid
string
path
True
Aggregate UUID
auto_provision_policy
string
query
False
If set to expand, the PATCH operation runs the recommended expansion of the aggregate.
  • Introduced in: 9.8
simulate
boolean
query
False
If set to true, the PATCH operation runs a simulated aggregate expansion with the provided input disk count and returns the proposed size of the new aggregate along with any associated warnings.
disk_size
integer
query
False
If set, PATCH only selects disks of the specified size.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
block_storage
block_storage
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier.
cloud_storage
cloud_storage
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier.
create_time
string
Timestamp of aggregate creation
data_encryption
data_encryption
dr_home_node
dr_home_node
Node where the aggregate resides after disaster recovery. The value for this field might differ from the 'node' field during switchover.
home_node
home_node
Node where the aggregate resides after giveback. The value for this field might differ from the value of the 'node' field during takeover.
inactive_data_reporting
name
string
Aggregate name
node
node
Node where the aggregate currently resides.
space
space
state
string
Operational state of the aggregate
uuid
string
Aggregate UUID
Example request
  "block_storage": {
    "hybrid_cache": {
      "disk_count": "6",
      "raid_type": "string",
      "size": "1612709888",
      "used": "26501122"
    "mirror": {
      "enabled": "",
      "state": "string"
    "plexes": [
        "name": "plex0"
    "primary": {
      "disk_count": "8",
      "disk_type": "string",
      "raid_size": "16",
  "cloud_storage": {
    "stores": [
        "cloud_store": {
          "name": "store1",
        "used": 0
  "create_time": "2018-01-01T12:00:00-04:00",
  "dr_home_node": {
    "name": "node1",
  "home_node": {
    "name": "node1",
  "inactive_data_reporting": {
    "start_time": "2019-12-12T12:00:00-04:00"
  "name": "node1_aggr_1",
  "node": {
    "name": "node1",
  "space": {
    "block_storage": {
      "available": "10156560384",
      "full_threshold_percent": 0,
      "inactive_user_data": "304448",
      "physical_used": "2461696",
      "size": "10156769280",
      "used": "2088960"
    "cloud_storage": {
      "used": "402743264"
    "efficiency": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "efficiency_without_snapshots": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "efficiency_without_snapshots_flexclones": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "footprint": "608896"
  "state": "string",
  "uuid": "string"
Status: 202, Accepted
job
job_link
num_records
integer
Number of records
records
array[aggregate]
warnings
array[aggregate_warning]
List of validation warnings and remediation advice for the aggregate simulate behavior.
  "job": {
    "uuid": "string"
  "records": [
      "block_storage": {
        "hybrid_cache": {
          "disk_count": "6",
          "used": "26501122"
        "mirror": {
          "enabled": "",
          "state": "string"
        "plexes": [
            "name": "plex0"
        "primary": {
          "disk_count": "8",
          "raid_size": "16",
      "cloud_storage": {
        "stores": [
            "cloud_store": {
              "name": "store1",
            "used": 0
      "dr_home_node": {
        "name": "node1",
      "home_node": {
        "name": "node1",
      "node": {
        "name": "node1",
      "space": {
        "block_storage": {
          "used": "2088960"
        "cloud_storage": {
          "used": "402743264"
        "efficiency": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
      "state": "string",
      "uuid": "string"
  "warnings": [
      "action": {
        "arguments": [
          "string"
        "message": "string"
      "name": "string",
      "warning": {
        "arguments": [
          "string"
        "message": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
262247
The value is invalid for the field.
460777
Failed to get information on the job.
786434
Cannot connect to node where the aggregate resides.
786435
Internal Error. Failed to create a communication handle.
786439
An aggregate already uses the specified name.
786447
Failed to modify the aggregate.
786456
Failed to add disks to the aggregate.
786458
Failed to rename aggregate.
786468
VLDB is offline.
786472
Node that hosts the aggregate is offline.
786479
Cannot find node ID for the node.
786491
Not enough spares on the node.
786730
Internal Error
786771
Aggregate does not exist.
786787
Aggregate is not online.
786808
Aggregate mirror failed.
786867
Specified aggregate resides on the remote cluster.
786911
Not every node in the cluster has the Data ONTAP version required for the feature.
786923
This operation is not allowed during the pre-commit phase of a 7-mode to clustered Data ONTAP transition.
786924
Internal error for an aggregate that is in the pre-commit phase of a 7-mode to clustered Data ONTAP transition.
786955
Modifying raidtype to raid_tec requires a minimum of six disks in the RAID Group.
786956
Modifying raidtype to raid_dp requires a minimum of four disks in the RAID Group.
786965
Spare Selection in userspace failed.
787046
Mirroring of a FabricPool is not allowed.
787092
The target field cannot be specified for this operation.
787144
Aggregate is not a FabricPool.
787156
Modifying the attributes of mirror object store is not allowed.
787169
Only one field can be modified per operation.
787170
Failed to patch the "block_storage.primary.disk_count" because the disk count specified is smaller than existing disk count.
787172
This query is only allowed during the modification of the specified field.
787178
Unmirroring an aggregate with a PATCH operation is not supported.
787187
Internal error. Failed to check if the aggregate is a FabricPool.
1258699
Cannot use all the disks specified for the requested operation.
1263500
Operation will lead to creation of new raid group.
1263501
Operation will exceed half of the maximum volume sizes allowed on the node.
1263502
One spare data partition from at least one of the chosen root-data1-data2 disks will not be used.
1263503
Operation will lead to downsizing of one or more disks.
1263504
Operation will lead to a spares low condition.
1263598
One or more selected disks will be partitioned.
1263624
Operation will lead to a no sparecore condition.
2425736
No matching node found for the UUID provided.
7209049
Cannot perform the operation because the aggregate is currently expanding.
7209075
Cannot perform the operation because the volume size limit for this system type would be exceeded.
13108106
Cannot run aggregate relocation because volume expand is in progress.
19726347
There are a number of unassigned disks visible to the node that owns this aggregate.
19726382
Another provisioning operation is in progress on this cluster. Wait a few minutes, and try the operation again.
19726390
Unable to automatically expand this aggregate.
19726391
Too many unassigned disks visible to the node that owns this aggregate.
19726392
Layout of this aggregate is not a supported configuration.
19726393
Failed to expand the aggregate. Aggregate expansion is not supported on this system.
19726394
Automatic aggregate expansion is not supported on systems with multiple data aggregates.
19726395
Automatic aggregate expansion is not supported when MetroCluster is not configured.
19726396
Automatic aggregate expansion is not supported when the DR group is not in a normal state.
19726397
Aggregates must contain disks with identical disk-types and disk-sizes.
19726402
Internal error. Unable to determine the MetroCluster configuration state.
19726538
Cannot perform the operation because the aggregate is not in a healthy state.
26542083
Destination node is at higher Data ONTAP version than source node.
26542084
Source node is at higher Data ONTAP version than destination node.
26542097
Unable to get D-blade ID of destination.
26542101
Unable to contact the source node.
26542102
Unable to contact the destination node.
26542120
An SVM migrate operation is in progress. When the migrate operation completes, try the operation again.
26542121
A MetroCluster disaster recovery operation is in progress. When the recovery operation completes, try the operation again.
196608334
Failed to modify the aggregate because it contains NAE volumes.
196608335
Failed to modify the aggregate because it contains non-encrypted volumes.
string
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count
integer
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
enabled
boolean
Specifies whether the aggregate uses HDDs with SSDs as a cache.
raid_type
string
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
size
integer
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
used
integer
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
mirror
enabled
boolean
Aggregate is SyncMirror protected
state
string
plex_reference
Plex
name
string
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
disk_count
integer
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache.
disk_type
string
The type of disk being used by the aggregate.
raid_size
integer
Option to specify the maximum number of disks that can be included in a RAID group.
raid_type
string
RAID type of the aggregate.
block_storage
hybrid_cache
hybrid_cache
mirror
mirror
plexes
array[plex_reference]
Plex reference for each plex in the aggregate.
primary
primary
cloud_store
Cloud store
name
string
uuid
string
cloud_storage_tier
cloud_store
cloud_store
Cloud store
used
integer
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes.
cloud_storage
attach_eligible
boolean
Specifies whether the aggregate is eligible for a cloud store to be attached.
stores
array[cloud_storage_tier]
Configuration information for each cloud storage portion of the aggregate.
tiering_fullness_threshold
integer
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations.
data_encryption
drive_protection_enabled
boolean
Specifies whether the aggregate uses self-encrypting drives with data protection enabled.
software_encryption_enabled
boolean
Specifies whether NetApp aggregate encryption is enabled. All data in the aggregate is encrypted.
dr_home_node
name
string
uuid
string
home_node
name
string
uuid
string
enabled
boolean
Specifes whether or not inactive data reporting is enabled on the aggregate.
start_time
string
Timestamp at which inactive data reporting was enabled on the aggregate.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
The most recent sample of I/O metrics for the aggregate.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
node
name
string
uuid
string
block_storage
available
integer
Space available in bytes.
integer
The aggregate used percentage at which 'monitor.volume.full' EMS is generated.
inactive_user_data
integer
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **.
physical_used
integer
Total physical used size of an aggregate in bytes.
size
integer
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve.
used
integer
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata.
cloud_storage
used
integer
Used space in bytes in the cloud store. Only applicable for aggregates with a cloud store tier.
efficiency
Storage efficiency
logical_used
integer
Logical used
ratio
number
Data reduction ratio (logical_used / used)
savings
integer
Space saved by storage efficiencies (logical_used - used)
Storage efficiency that does not include the savings provided by Snapshot copies.
logical_used
integer
Logical used
ratio
number
savings
integer
Storage efficiency that does not include the savings provided by Snapshot copies and FlexClones.
logical_used
integer
Logical used
ratio
number
savings
integer
space
block_storage
block_storage
cloud_storage
cloud_storage
efficiency
efficiency
Storage efficiency
footprint
integer
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the aggregate.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
aggregate
block_storage
block_storage
cloud_storage
cloud_storage
create_time
string
data_encryption
data_encryption
dr_home_node
dr_home_node
home_node
home_node
name
string
Aggregate name
node
node
space
space
state
string
uuid
string
Aggregate UUID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
action
arguments
array[string]
Arguments present in the specified action message.
code
integer
Corrective action code of the specified action.
message
string
Specifies the corrective action to be taken to resolve the issue.
warning
arguments
array[string]
Arguments present in the warning message encountered.
code
integer
Warning code of the warning encountered.
message
string
Details of the warning encountered by the aggregate simulate query.
aggregate_warning
action
action
name
string
Name of the entity that returns the warning.
warning
warning
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
