Update an aggregate specified by the UUID
PATCH /storage/aggregates/{uuid}
Introduced In: 9.6
Updates the aggregate specified by the UUID with the properties in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate add-disks -
storage aggregate mirror -
storage aggregate modify -
storage aggregate relocation start -
storage aggregate rename
uuid |
string |
path |
True |
Aggregate UUID |
auto_provision_policy |
string |
query |
False |
If set to expand, the PATCH operation runs the recommended expansion of the aggregate.
simulate |
boolean |
query |
False |
If set to true, the PATCH operation runs a simulated aggregate expansion with the provided input disk count and returns the proposed size of the new aggregate along with any associated warnings.
disk_size |
integer |
query |
False |
If set, PATCH only selects disks of the specified size. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
_tags |
array[string] |
Tags are an optional way to track the uses of a resource. Tag values must be formatted as key:value strings. |
block_storage |
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier. |
cloud_storage |
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier. |
create_time |
string |
Timestamp of aggregate creation. |
data_encryption |
home_node |
Node where the aggregate resides after giveback. The value for this field might differ from the value of the 'node' field during takeover. |
inactive_data_reporting |
inode_attributes |
is_spare_low |
boolean |
Specifies whether the aggregate is in a spares low condition on any of the RAID groups. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
name |
string |
Aggregate name. |
node |
Node where the aggregate currently resides. |
sidl_enabled |
boolean |
Specifies whether or not SIDL is enabled on the aggregate. |
snapshot |
space |
state |
string |
Operational state of the aggregate. |
uuid |
string |
Aggregate UUID. |
volume-count |
integer |
Number of volumes in the aggregate. |
Example request
"_tags": [
"team:csi",
"environment:test"
"block_storage": {
"hybrid_cache": {
"disk_count": 6,
"disk_type": "string",
"raid_size": 24,
"raid_type": "string",
"simulated_raid_groups": [
"name": "string"
"size": 1612709888,
"storage_pools": [
"storage_pool": {
"name": "storage_pool_1",
"used": 26501122
"mirror": {
"enabled": "",
"state": "string"
"plexes": [
"name": "plex0"
"primary": {
"disk_count": 8,
"raid_size": 16,
"name": "string",
"storage_type": "string"
"cloud_storage": {
"stores": [
"cloud_store": {
"name": "store1",
"used": 0
"create_time": "2018-01-01 12:00:00 -0400",
"home_node": {
"name": "node1",
"inactive_data_reporting": {
"start_time": "2019-12-12 12:00:00 -0400"
"inode_attributes": {
"file_private_capacity": 31136,
"file_public_capacity": 31136,
"files_private_used": 502,
"files_total": 31136,
"files_used": 97,
"max_files_available": 31136,
"max_files_possible": 2844525,
"max_files_used": 97,
"used_percent": 5,
"version": 4
"is_spare_low": "",
"name": "node1_aggr_1",
"node": {
"name": "node1",
"snapshot": {
"files_total": 10,
"files_used": 3,
"max_files_available": 5,
"max_files_used": 50
"space": {
"block_storage": {
"aggregate_metadata": 2655,
"aggregate_metadata_percent": 8,
"available": 10156560384,
"data_compacted_count": 1990000,
"data_compaction_space_saved": 1996000,
"data_compaction_space_saved_percent": 27,
"full_threshold_percent": 0,
"inactive_user_data": 304448,
"inactive_user_data_percent": 0,
"physical_used": 2461696,
"physical_used_percent": 50,
"size": 10156769280,
"used": 2088960,
"used_including_snapshot_reserve": 674685,
"used_including_snapshot_reserve_percent": 35,
"used_percent": 50,
"volume_deduplication_shared_count": 1990000,
"volume_deduplication_space_saved": 1996000,
"volume_deduplication_space_saved_percent": 27,
"volume_footprints_percent": 14
"cloud_storage": {
"used": 402743264
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0,
"wise_tsse_min_used_capacity_pct": 0
"efficiency_without_snapshots": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"efficiency_without_snapshots_flexclones": {
"logical_used": 0,
"ratio": 0,
"savings": 0
"footprint": 608896,
"logical_used": 2461696,
"logical_used_percent": 50,
"snapshot": {
"available": 2000,
"reserve_percent": 20,
"total": 5000,
"used": 3000,
"used_percent": 45
"total_provisioned_space": 20971520
"state": "string",
"uuid": "string",
"volume-count": 0
Status: 200, Ok
job |
num_records |
integer |
Number of records |
records |
array[aggregate] |
warnings |
array[aggregate_warning] |
List of validation warnings and remediation advice for the aggregate simulate behavior. |
"job": {
"uuid": "string"
"num_records": 1,
"records": [
"_tags": [
"team:csi",
"environment:test"
"block_storage": {
"hybrid_cache": {
"disk_count": 6,
"raid_size": 24,
"name": "string"
"size": 1612709888,
"storage_pools": [
"storage_pool": {
"used": 26501122
"mirror": {
"enabled": "",
"state": "string"
"plexes": [
"name": "plex0"
"primary": {
"disk_count": 8,
"raid_size": 16,
"name": "string",
"cloud_storage": {
"stores": [
"cloud_store": {
"name": "store1",
"used": 0
"home_node": {
"name": "node1",
"files_used": 97,
"used_percent": 5,
"version": 4
"is_spare_low": "",
"node": {
"name": "node1",
"snapshot": {
"files_total": 10,
"files_used": 3,
"space": {
"block_storage": {
"used": 2088960,
"used_percent": 50,
"cloud_storage": {
"used": 402743264
"efficiency": {
"logical_used": 0,
"ratio": 0,
"savings": 0,
"logical_used": 0,
"ratio": 0,
"savings": 0
"logical_used": 0,
"ratio": 0,
"savings": 0
"snapshot": {
"available": 2000,
"total": 5000,
"used": 3000,
"used_percent": 45
"state": "string",
"uuid": "string",
"volume-count": 0
"warnings": [
"action": {
"arguments": [
"string"
"message": "string"
"name": "string",
"warning": {
"arguments": [
"string"
"message": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262247 |
The value is invalid for the field. |
460777 |
Failed to get information on the job. |
786434 |
Cannot connect to node where the aggregate resides. |
786435 |
Internal Error. Failed to create a communication handle. |
786439 |
An aggregate already uses the specified name. |
786447 |
Failed to modify the aggregate. |
786456 |
Failed to add disks to the aggregate. |
786458 |
Failed to rename aggregate. |
786465 |
Failed to take aggregate offline because of the reason outlined in the message. |
786467 |
Failed to take aggregate online because of the reason outlined in the message. |
786468 |
VLDB is offline. |
786472 |
Node that hosts the aggregate is offline. |
786479 |
Cannot find node ID for the node. |
786491 |
Not enough spares on the node. |
786730 |
Internal Error |
786771 |
Aggregate does not exist. |
786787 |
Aggregate is not online. |
786808 |
Aggregate mirror failed. |
786867 |
Specified aggregate resides on the remote cluster. |
786911 |
Not every node in the cluster has the Data ONTAP version required for the feature. |
786923 |
This operation is not allowed during the pre-commit phase of a 7-mode to clustered Data ONTAP transition. |
786924 |
Internal error for an aggregate that is in the pre-commit phase of a 7-mode to clustered Data ONTAP transition. |
786955 |
Modifying raidtype to raid_tec requires a minimum of six disks in the RAID Group. |
786956 |
Modifying raidtype to raid_dp requires a minimum of four disks in the RAID Group. |
786965 |
Spare Selection in userspace failed. |
787046 |
Mirroring of a FabricPool is not allowed. |
787092 |
The target field cannot be specified for this operation. |
787144 |
Aggregate is not a FabricPool. |
787156 |
Modifying the attributes of mirror object store is not allowed. |
787169 |
Only one field can be modified per operation. |
787170 |
Failed to patch the "block_storage.primary.disk_count" because the disk count specified is smaller than existing disk count. |
787172 |
This query is only allowed during the modification of the specified field. |
787178 |
Unmirroring an aggregate with a PATCH operation is not supported. |
787187 |
Internal error. Failed to check if the aggregate is a FabricPool. |
787266 |
Invalid aggregate state. This state is not supported for a PATCH operation. |
787273 |
Allocation unit count is not valid. |
787274 |
Raidtype is not valid. |
787275 |
Patch request with multiple records is not valid. |
787276 |
Storage pool name and uuid do not match. |
787277 |
Storage pool name and uuid are empty. |
787278 |
Incorrect storage pool name specified. |
787279 |
Incorrect storage pool uuid specified. |
787280 |
Allocation unit count specified is smaller than the existing allocation unit count. |
787281 |
Cannot modify RAID type of aggregate hybrid cache tier. |
787282 |
RAID group must be specified on a disk addition to an aggregate with mixed RAID types. |
787283 |
RAID group must be specified on a disk addition to a Flash Pool aggregate. |
787284 |
The specified RAID group uses capacity from one or more storage pools. |
787287 |
Cannot add physical SSD cache because aggregate uses cache capacity from a storage pool. |
787288 |
Cannot add storage pool units because aggregate uses physical SSD cache. |
787289 |
Incorrect raid_group specified during first time addition of physical SSD cache to an aggregate. |
787291 |
Cannot specify RAID group which is located on the aggregate primary tier. |
787293 |
Cannot specify RAID group which is located on the aggregate cache tier. |
787294 |
This query is only allowed during the modification of the specific fields. |
787295 |
The storage pool allocation units count is required. |
787419 |
An aggregate already uses the specified name in either of the MetroCluster sites. |
787420 |
Substring mcc_renamed is not allowed to be used as an aggregate name in MetroCluster configurations. |
1258699 |
Cannot use all the disks specified for the requested operation. |
1263500 |
Operation will lead to creation of new raid group. |
1263501 |
Operation will exceed half of the maximum volume sizes allowed on the node. |
1263502 |
One spare data partition from at least one of the chosen root-data1-data2 disks will not be used. |
1263503 |
Operation will lead to downsizing of one or more disks. |
1263504 |
Operation will lead to a spares low condition. |
1263598 |
One or more selected disks will be partitioned. |
1263624 |
Operation will lead to a no sparecore condition. |
2425736 |
No matching node found for the UUID provided. |
7208962 |
Aggregate in an inconsistent state. |
7208993 |
Failed to offline as the volume is being used. |
7209033 |
CIFS open files prevent operation. |
7209049 |
Cannot perform the operation because the aggregate is currently expanding. |
7209075 |
Cannot perform the operation because the volume size limit for this system type would be exceeded. |
7209090 |
Inconsistent state. |
7209183 |
Volume is a partial volume. |
7209229 |
This version of ONTAP does not recognize the filesystem. It is probably from a later version of the software and is being left offline. |
7209246 |
The specified operation could not be completed as the volume is currently busy. |
7209247 |
The volume was not found. |
7209263 |
Container has failed. |
7209271 |
wafliron is currently active. |
7209275 |
Container was created in an unclustered ONTAP deployment. |
7209463 |
Nvfile replay pending. |
7209966 |
Another online request is already in progress for aggregate. The previous online request is waiting on a response from the licensing manager. |
11206666 |
Storage pool is not healthy. |
11210659 |
11210662 |
Adding capacity from storage pool to a mirrored aggregate is not supported. |
11210667 |
Storage pool does not have enough spare allocation units. |
11210670 |
Cannot add capacity from storage pool to aggregate, because currently allocated capacity to the aggregate does not span across all disks belonging to the storage pool. |
11210672 |
Cannot grow aggregate as no capacity is allocated to it from storage pool. |
11210673 |
Mixing of physical SSDs and capacity from a storage pool is not allowed in same aggregate. |
11210675 |
Capacity in storage pool belongs to different fault isolation domain than aggregate. |
11210678 |
Storage pool does not have enough disks to create RAID groups of same raid type as that of already allocated cache tier. |
11210679 |
Storage pool does not have enough disks to create RAID groups of type RAID-DP. |
11210680 |
Storage pool does not have enough disks to create RAID groups of same raid type as that of the aggregate. |
11210685 |
Storage pool does not have enough disks to create RAID groups of type RAID-TEC. |
11210688 |
Capacity from storage pool cannot be added to an SSD aggregate and a Flash Pool. |
13108106 |
Cannot run aggregate relocation because volume expand is in progress. |
19726347 |
There are a number of unassigned disks visible to the node that owns this aggregate. |
19726382 |
Another provisioning operation is in progress on this cluster. Wait a few minutes, and try the operation again. |
19726390 |
Unable to automatically expand this aggregate. |
19726391 |
Too many unassigned disks visible to the node that owns this aggregate. |
19726392 |
Layout of this aggregate is not a supported configuration. |
19726393 |
Failed to expand the aggregate. Aggregate expansion is not supported on this system. |
19726394 |
Automatic aggregate expansion is not supported on systems with multiple data aggregates. |
19726395 |
Automatic aggregate expansion is not supported when MetroCluster is not configured. |
19726396 |
Automatic aggregate expansion is not supported when the DR group is not in a normal state. |
19726397 |
Aggregates must contain disks with identical disk-types and disk-sizes. |
19726402 |
Internal error. Unable to determine the MetroCluster configuration state. |
19726538 |
Cannot perform the operation because the aggregate is not in a healthy state. |
19726541 |
Cannot perform the operation because the specified aggregate is a root aggregate. |
19726544 |
PATCH on the aggregate endpoint is not supported on this version of ONTAP. |
26542083 |
Destination node is at higher Data ONTAP version than source node. |
26542084 |
Source node is at higher Data ONTAP version than destination node. |
26542097 |
Unable to get D-blade ID of destination. |
26542101 |
Unable to contact the source node. |
26542102 |
Unable to contact the destination node. |
26542120 |
An SVM migrate operation is in progress. When the migrate operation completes, try the operation again. |
26542121 |
A MetroCluster disaster recovery operation is in progress. When the recovery operation completes, try the operation again. |
196608334 |
Failed to modify the aggregate because it contains NAE volumes. |
196608335 |
Failed to modify the aggregate because it contains non-encrypted volumes. |
href |
string |
_links
added_data_disk_count |
integer |
Number of added data disks in RAID group. |
added_parity_disk_count |
integer |
Number of added parity disks in RAID group. |
existing_data_disk_count |
integer |
Number of existing data disks in the RAID group. |
existing_parity_disk_count |
integer |
Number of existing parity disks in the RAID group. |
is_partition |
boolean |
Indicates whether the disk is partitioned (true) or whole (false). |
name |
string |
Name of the raid group. |
usable_size |
integer |
Usable size of each disk, in bytes. |
storage_pool_reference
Shared Storage Pool
name |
string |
uuid |
string |
storage_pools
allocation_units_count |
integer |
Allocation count of storage pool. |
storage_pool |
Shared Storage Pool |
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count |
integer |
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
disk_type |
string |
Type of disk being used by the aggregate's cache tier. |
enabled |
boolean |
Specifies whether the aggregate uses HDDs with SSDs as a cache. |
raid_size |
integer |
Option to specify the maximum number of disks that can be included in a RAID group. |
raid_type |
string |
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'. |
simulated_raid_groups |
array[simulated_raid_groups] |
size |
integer |
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
storage_pools |
array[storage_pools] |
List of storage pool properties and allocation_units_count for aggregate. |
used |
integer |
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'. |
mirror
enabled |
boolean |
Aggregate is SyncMirror protected |
state |
string |
plex_reference
Plex
name |
string |
integer |
integer |
data_disk_count |
integer |
Number of data disks in RAID group. |
integer |
integer |
is_partition |
boolean |
name |
string |
parity_disk_count |
integer |
Number of parity disks in RAID group. |
raid_type |
string |
RAID type of the aggregate. |
usable_size |
integer |
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
disk_count |
integer |
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache. |
disk_type |
string |
The type of disk being used by the aggregate. |
raid_size |
integer |
raid_type |
string |
block_storage
hybrid_cache |
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs. |
mirror |
plexes |
array[plex_reference] |
Plex reference for each plex in the aggregate. |
primary |
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details. |
storage_type |
string |
Type of aggregate. |
uses_partitions |
boolean |
If true, aggregate is using shared disks. |
cloud_store
Cloud store
name |
string |
uuid |
string |
cloud_storage_tier
cloud_store |
Cloud store |
used |
integer |
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes. |
cloud_storage
attach_eligible |
boolean |
Specifies whether the aggregate is eligible for a cloud store to be attached. |
migrate_threshold |
integer |
Specifies the minimum percentage of performance tier free space that must exist in order for migration of data from the capacity tier to performance tier to be allowed. Only valid for PATCH operations. |
stores |
array[cloud_storage_tier] |
Configuration information for each cloud storage portion of the aggregate. |
tiering_fullness_threshold |
integer |
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations. |
data_encryption
drive_protection_enabled |
boolean |
Specifies whether the aggregate uses self-encrypting drives with data protection enabled. |
software_encryption_enabled |
boolean |
Specifies whether NetApp aggregate encryption is enabled. All data in the aggregate is encrypted. |
dr_home_node
Node where the aggregate resides after disaster recovery. The value for this field might differ from the 'node' field during switchover.
name |
string |
uuid |
string |
home_node
name |
string |
uuid |
string |
enabled |
boolean |
Specifies whether or not inactive data reporting is enabled on the aggregate. |
start_time |
string |
Timestamp at which inactive data reporting was enabled on the aggregate. |
inode_attributes
file_private_capacity |
integer |
Number of files that can currently be stored on disk for system metadata files. This number will dynamically increase as more system files are created. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
file_public_capacity |
integer |
Number of files that can currently be stored on disk for user-visible files. This number will dynamically increase as more user-visible files are created. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
files_private_used |
integer |
Number of system metadata files used. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
files_total |
integer |
Maximum number of user-visible files that this referenced file system can currently hold. If the referenced file system is restricted or offline, a value of 0 is returned. |
files_used |
integer |
Number of user-visible files used in the referenced file system. If the referenced file system is restricted or offline, a value of 0 is returned. |
max_files_available |
integer |
The count of the maximum number of user-visible files currently allowable on the referenced file system. |
max_files_possible |
integer |
The largest value to which the maxfiles-available parameter can be increased by reconfiguration, on the referenced file system. |
max_files_used |
integer |
The number of user-visible files currently in use on the referenced file system. |
used_percent |
integer |
The percentage of disk space currently in use based on user-visible file count on the referenced file system. |
version |
integer |
The inofile-version of the aggregate. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
other |
integer |
read |
integer |
total |
integer |
write |
integer |
metric
The most recent sample of I/O metrics for the aggregate.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
node
name |
string |
uuid |
string |
snapshot
files_total |
integer |
Total files allowed in snapshots |
files_used |
integer |
Total files created in snapshots |
integer |
Maximum files available for snapshots |
max_files_used |
integer |
Files in use by snapshots |
block_storage
aggregate_metadata |
integer |
Space used by different metafiles and internal operations inside the aggregate, in bytes. |
aggregate_metadata_percent |
integer |
Aggregate metadata as a percentage. |
available |
integer |
Space available in bytes. |
data_compacted_count |
integer |
Amount of compacted data in bytes. |
data_compaction_space_saved |
integer |
Space saved in bytes by compacting the data. |
data_compaction_space_saved_percent |
integer |
Percentage saved by compacting the data. |
full_threshold_percent |
integer |
The aggregate used percentage at which 'monitor.volume.full' EMS is generated. |
inactive_user_data |
integer |
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **. |
inactive_user_data_percent |
integer |
The percentage of inactive user data in the block storage. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data_percent or **. |
physical_used |
integer |
Total physical used size of an aggregate in bytes. |
physical_used_percent |
integer |
Physical used percentage. |
size |
integer |
Total usable space in bytes, not including WAFL reserve and aggregate snapshot reserve. |
used |
integer |
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata. |
used_including_snapshot_reserve |
integer |
Total used including the snapshot reserve, in bytes. |
used_including_snapshot_reserve_percent |
integer |
Total used including the Snapshot reserve as a percentage. |
used_percent |
integer |
Aggregate used percentage. |
volume_deduplication_shared_count |
integer |
Amount of shared bytes counted by storage efficiency. |
volume_deduplication_space_saved |
integer |
Amount of space saved in bytes by storage efficiency. |
volume_deduplication_space_saved_percent |
integer |
Percentage of space saved by storage efficiency. |
volume_footprints_percent |
integer |
A summation of volume footprints inside the aggregate, as a percentage. A volume's footprint is the amount of space being used for the volume in the aggregate. |
cloud_storage
used |
integer |
Used space in bytes in the cloud store. Only applicable for aggregates with a cloud store tier. |
efficiency
Storage efficiency.
auto_adaptive_compression_savings |
boolean |
Indicates whether or not aggregate has auto adaptive compression savings. |
cross_volume_background_dedupe |
boolean |
Indicates whether or not cross volume background deduplication is enabled. |
cross_volume_dedupe_savings |
boolean |
Indicates whether or not aggregate has cross volume deduplication savings. |
cross_volume_inline_dedupe |
boolean |
Indicates whether or not cross volume inline deduplication is enabled. |
enable_workload_informed_tsse |
boolean |
Indicates whether Workload Informed TSSE is enabled on the system. |
logical_used |
integer |
Logical used |
ratio |
number |
Data reduction ratio (logical_used / used) |
savings |
integer |
Space saved by storage efficiencies (logical_used - used) |
wise_tsse_min_used_capacity_pct |
integer |
Minimum amount of used data in aggregate required to trigger cold compression on TSSE volumes. |
Storage efficiency that does not include the savings provided by snapshots.
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
Storage efficiency that does not include the savings provided by snapshots and Flexclone volumes.
logical_used |
integer |
Logical used |
ratio |
number |
savings |
integer |
snapshot
available |
integer |
Available space for snapshots in bytes |
reserve_percent |
integer |
Percentage of space reserved for snapshots |
total |
integer |
Total space for snapshots in bytes |
used |
integer |
Space used by snapshots in bytes |
used_percent |
integer |
Percentage of disk space used by snapshots |
space
| Name | Type | Description | ||
block_storage |
cloud_storage |
efficiency |
Storage efficiency. |
efficiency_without_snapshots |
Storage efficiency that does not include the savings provided by snapshots. |
efficiency_without_snapshots_flexclones |
Storage efficiency that does not include the savings provided by snapshots and Flexclone volumes. |
footprint |
integer |
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **. |
logical_used |
integer |
Total volume logical used size of an aggregate in bytes.
logical_used_percent |
integer |
Total volume logical used percentage.
snapshot |
total_provisioned_space |
integer |
A summation of volume size, in bytes. This includes all of the volumes inside the aggregate. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either total_provisioned_space or **. |
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
statistics
The real time I/O statistics for the aggregate.
iops_raw |
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
throughput_raw |
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
aggregate
_tags |
array[string] |
block_storage |
cloud_storage |
create_time |
string |
data_encryption |
home_node |
inode_attributes |
is_spare_low |
boolean |
name |
string |
Aggregate name. |
node |
sidl_enabled |
boolean |
snapshot |
space |
state |
string |
uuid |
string |
Aggregate UUID. |
volume-count |
integer |
job_link
uuid |
string |
action
arguments |
array[string] |
Arguments present in the specified action message. |
code |
integer |
Corrective action code of the specified action. |
message |
string |
Specifies the corrective action to be taken to resolve the issue. |
warning
arguments |
array[string] |
Arguments present in the warning message encountered. |
code |
integer |
Warning code of the warning encountered. |
message |
string |
Details of the warning encountered by the aggregate simulate query. |
aggregate_warning
action |
name |
string |
Name of the entity that returns the warning. |
warning |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
