REST API reference
Update an aggregate specified by the UUID
Updates the properties of a specified aggregate by providing the desired configuration in the request body. This action initiates a job, which you can track using the returned job link.
HTTP method and endpoint
PATCH /storage/aggregates/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates the aggregate specified by the UUID with the properties in the body. This request starts a job and returns a link to that job.
  • storage aggregate add-disks
  • storage aggregate mirror
  • storage aggregate modify
  • storage aggregate relocation start
  • storage aggregate rename
uuid
string
path
True
Aggregate UUID
auto_provision_policy
string
query
False
If set to expand, the PATCH operation runs the recommended expansion of the aggregate.
  • Introduced in: 9.8
simulate
boolean
query
False
If set to true, the PATCH operation runs a simulated aggregate expansion with the provided input disk count and returns the proposed size of the new aggregate along with any associated warnings.
disk_size
integer
query
False
If set, PATCH only selects disks of the specified size.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
_links
_links
block_storage
block_storage
Configuration information for the locally attached portion of the aggregate. When a cloud store is also used by this aggregate, this is referred to as the performance tier.
cloud_storage
cloud_storage
Configuration information for the cloud storage portion of the aggregate. This is referred to as the capacity tier.
create_time
string
Timestamp of aggregate creation.
data_encryption
data_encryption
dr_home_node
dr_home_node
Node where the aggregate resides after disaster recovery. The value for this field might differ from the 'node' field during switchover.
home_node
home_node
Node where the aggregate resides after giveback. The value for this field might differ from the value of the 'node' field during takeover.
inactive_data_reporting
is_spare_low
boolean
Specifies whether the aggregate is in a spares low condition on any of the RAID groups. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
name
string
Aggregate name.
node
node
Node where the aggregate currently resides.
recommendation_spares
array[aggregate_spare]
Information on the aggregate's remaining hot spare disks.
sidl_enabled
boolean
Specifies whether or not SIDL is enabled on the aggregate.
snapshot
snapshot
space
space
state
string
Operational state of the aggregate.
uuid
string
Aggregate UUID.
volume-count
integer
Number of volumes in the aggregate.
Example request
  "block_storage": {
    "hybrid_cache": {
      "disk_count": 6,
      "disk_type": "string",
      "raid_size": 24,
      "raid_type": "string",
      "simulated_raid_groups": [
          "name": "string"
      "size": 1612709888,
      "storage_pools": [
          "storage_pool": {
            "name": "storage_pool_1",
      "used": 26501122
    "mirror": {
      "enabled": "",
      "state": "string"
    "plexes": [
        "name": "plex0"
    "primary": {
      "disk_count": 8,
      "raid_size": 16,
          "name": "string",
    "storage_type": "string"
  "cloud_storage": {
    "stores": [
        "cloud_store": {
          "name": "store1",
        "used": 0
  "create_time": "2018-01-01T12:00:00-04:00",
  "dr_home_node": {
    "name": "node1",
  "home_node": {
    "name": "node1",
  "inactive_data_reporting": {
    "start_time": "2019-12-12T12:00:00-04:00"
  "is_spare_low": "",
  "name": "node1_aggr_1",
  "node": {
    "name": "node1",
  "recommendation_spares": [
      "checksum_style": "string",
      "disk_class": "solid_state",
      "is_partition": 1,
      "layout_requirements": [
          "aggregate_min_disks": 6,
          "raid_group": {
            "default": 16,
            "max": 28,
            "min": 5
      "node": {
        "name": "node1",
      "size": 10156769280,
      "syncmirror_pool": "string",
      "total": 10,
      "usable": 9
  "snapshot": {
    "files_total": 10,
    "files_used": 3,
    "max_files_available": 5,
    "max_files_used": 50
  "space": {
    "block_storage": {
      "aggregate_metadata": 2655,
      "aggregate_metadata_percent": 8,
      "available": 10156560384,
      "data_compacted_count": 1990000,
      "data_compaction_space_saved": 1996000,
      "data_compaction_space_saved_percent": 27,
      "full_threshold_percent": 0,
      "inactive_user_data": 304448,
      "inactive_user_data_percent": 0,
      "physical_used": 2461696,
      "physical_used_percent": 50,
      "used": 2088960,
      "used_including_snapshot_reserve": 674685,
      "used_including_snapshot_reserve_percent": 35,
      "volume_deduplication_shared_count": 1990000,
      "volume_deduplication_space_saved": 1996000,
      "volume_deduplication_space_saved_percent": 27,
      "volume_footprints_percent": 14
    "cloud_storage": {
      "used": 402743264
    "efficiency": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "efficiency_without_snapshots": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "efficiency_without_snapshots_flexclones": {
      "logical_used": 0,
      "ratio": 0,
      "savings": 0
    "footprint": 608896,
    "snapshot": {
      "available": 2000,
      "reserve_percent": 20,
      "total": 5000,
      "used": 3000,
      "used_percent": 45
  "state": "string",
  "uuid": "string",
  "volume-count": 0
Status: 200, Ok
job
job_link
num_records
integer
Number of records
records
array[aggregate]
warnings
array[aggregate_warning]
List of validation warnings and remediation advice for the aggregate simulate behavior.
  "job": {
    "uuid": "string"
  "num_records": 1,
  "records": [
      "block_storage": {
        "hybrid_cache": {
          "disk_count": 6,
          "raid_size": 24,
              "name": "string"
          "size": 1612709888,
          "storage_pools": [
              "storage_pool": {
          "used": 26501122
        "mirror": {
          "enabled": "",
          "state": "string"
        "plexes": [
            "name": "plex0"
        "primary": {
          "disk_count": 8,
          "raid_size": 16,
              "name": "string",
      "cloud_storage": {
        "stores": [
            "cloud_store": {
              "name": "store1",
            "used": 0
      "dr_home_node": {
        "name": "node1",
      "home_node": {
        "name": "node1",
      "is_spare_low": "",
      "node": {
        "name": "node1",
          "is_partition": 1,
              "raid_group": {
                "default": 16,
                "max": 28,
                "min": 5
          "node": {
            "name": "node1",
          "total": 10,
          "usable": 9
      "snapshot": {
        "files_total": 10,
        "files_used": 3,
      "space": {
        "block_storage": {
          "used": 2088960,
        "cloud_storage": {
          "used": 402743264
        "efficiency": {
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
          "logical_used": 0,
          "ratio": 0,
          "savings": 0
        "snapshot": {
          "available": 2000,
          "total": 5000,
          "used": 3000,
          "used_percent": 45
      "state": "string",
      "uuid": "string",
      "volume-count": 0
  "warnings": [
      "action": {
        "arguments": [
          "string"
        "message": "string"
      "name": "string",
      "warning": {
        "arguments": [
          "string"
        "message": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
262247
The value is invalid for the field.
460777
Failed to get information on the job.
786434
Cannot connect to node where the aggregate resides.
786435
Internal Error. Failed to create a communication handle.
786439
An aggregate already uses the specified name.
786447
Failed to modify the aggregate.
786456
Failed to add disks to the aggregate.
786458
Failed to rename aggregate.
786465
Failed to take aggregate offline because of the reason outlined in the message.
786467
Failed to take aggregate online because of the reason outlined in the message.
786468
VLDB is offline.
786472
Node that hosts the aggregate is offline.
786479
Cannot find node ID for the node.
786491
Not enough spares on the node.
786730
Internal Error
786771
Aggregate does not exist.
786787
Aggregate is not online.
786808
Aggregate mirror failed.
786867
Specified aggregate resides on the remote cluster.
786911
Not every node in the cluster has the Data ONTAP version required for the feature.
786923
This operation is not allowed during the pre-commit phase of a 7-mode to clustered Data ONTAP transition.
786924
Internal error for an aggregate that is in the pre-commit phase of a 7-mode to clustered Data ONTAP transition.
786955
Modifying raidtype to raid_tec requires a minimum of six disks in the RAID Group.
786956
Modifying raidtype to raid_dp requires a minimum of four disks in the RAID Group.
786965
Spare Selection in userspace failed.
787046
Mirroring of a FabricPool is not allowed.
787092
The target field cannot be specified for this operation.
787144
Aggregate is not a FabricPool.
787156
Modifying the attributes of mirror object store is not allowed.
787169
Only one field can be modified per operation.
787170
Failed to patch the "block_storage.primary.disk_count" because the disk count specified is smaller than existing disk count.
787172
This query is only allowed during the modification of the specified field.
787178
Unmirroring an aggregate with a PATCH operation is not supported.
787187
Internal error. Failed to check if the aggregate is a FabricPool.
787266
Invalid aggregate state. This state is not supported for a PATCH operation.
787273
Allocation unit count is not valid.
787274
Raidtype is not valid.
787275
Patch request with multiple records is not valid.
787276
Storage pool name and uuid do not match.
787277
Storage pool name and uuid are empty.
787278
Incorrect storage pool name specified.
787279
Incorrect storage pool uuid specified.
787280
Allocation unit count specified is smaller than the existing allocation unit count.
787281
Cannot modify RAID type of aggregate hybrid cache tier.
787282
RAID group must be specified on a disk addition to an aggregate with mixed RAID types.
787283
RAID group must be specified on a disk addition to a Flash Pool aggregate.
787284
The specified RAID group uses capacity from one or more storage pools.
787287
Cannot add physical SSD cache because aggregate uses cache capacity from a storage pool.
787288
Cannot add storage pool units because aggregate uses physical SSD cache.
787289
Incorrect raid_group specified during first time addition of physical SSD cache to an aggregate.
787291
Cannot specify RAID group which is located on the aggregate primary tier.
787293
Cannot specify RAID group which is located on the aggregate cache tier.
787294
This query is only allowed during the modification of the specific fields.
787295
The storage pool allocation units count is required.
1258699
Cannot use all the disks specified for the requested operation.
1263500
Operation will lead to creation of new raid group.
1263501
Operation will exceed half of the maximum volume sizes allowed on the node.
1263502
One spare data partition from at least one of the chosen root-data1-data2 disks will not be used.
1263503
Operation will lead to downsizing of one or more disks.
1263504
Operation will lead to a spares low condition.
1263598
One or more selected disks will be partitioned.
1263624
Operation will lead to a no sparecore condition.
2425736
No matching node found for the UUID provided.
7208962
Aggregate in an inconsistent state.
7208993
Failed to offline as the volume is being used.
7209033
CIFS open files prevent operation.
7209049
Cannot perform the operation because the aggregate is currently expanding.
7209075
Cannot perform the operation because the volume size limit for this system type would be exceeded.
7209090
Inconsistent state.
7209183
Volume is a partial volume.
7209229
This version of ONTAP does not recognize the filesystem. It is probably from a later version of the software and is being left offline.
7209246
The specified operation could not be completed as the volume is currently busy.
7209247
The volume was not found.
7209263
Container has failed.
7209271
wafliron is currently active.
7209275
Container was created in an unclustered ONTAP deployment.
7209463
Nvfile replay pending.
7209966
Another online request is already in progress for aggregate. The previous online request is waiting on a response from the licensing manager.
11206666
Storage pool is not healthy.
11210659
11210662
Adding capacity from storage pool to a mirrored aggregate is not supported.
11210667
Storage pool does not have enough spare allocation units.
11210670
Cannot add capacity from storage pool to aggregate, because currently allocated capacity to the aggregate does not span across all disks belonging to the storage pool.
11210672
Cannot grow aggregate as no capacity is allocated to it from storage pool.
11210673
Mixing of physical SSDs and capacity from a storage pool is not allowed in same aggregate.
11210675
Capacity in storage pool belongs to different fault isolation domain than aggregate.
11210678
Storage pool does not have enough disks to create RAID groups of same raid type as that of already allocated cache tier.
11210679
Storage pool does not have enough disks to create RAID groups of type RAID-DP.
11210680
Storage pool does not have enough disks to create RAID groups of same raid type as that of the aggregate.
11210685
Storage pool does not have enough disks to create RAID groups of type RAID-TEC.
11210688
Capacity from storage pool cannot be added to an SSD aggregate and a Flash Pool.
13108106
Cannot run aggregate relocation because volume expand is in progress.
19726347
There are a number of unassigned disks visible to the node that owns this aggregate.
19726382
Another provisioning operation is in progress on this cluster. Wait a few minutes, and try the operation again.
19726390
Unable to automatically expand this aggregate.
19726391
Too many unassigned disks visible to the node that owns this aggregate.
19726392
Layout of this aggregate is not a supported configuration.
19726393
Failed to expand the aggregate. Aggregate expansion is not supported on this system.
19726394
Automatic aggregate expansion is not supported on systems with multiple data aggregates.
19726395
Automatic aggregate expansion is not supported when MetroCluster is not configured.
19726396
Automatic aggregate expansion is not supported when the DR group is not in a normal state.
19726397
Aggregates must contain disks with identical disk-types and disk-sizes.
19726402
Internal error. Unable to determine the MetroCluster configuration state.
19726538
Cannot perform the operation because the aggregate is not in a healthy state.
26542083
Destination node is at higher Data ONTAP version than source node.
26542084
Source node is at higher Data ONTAP version than destination node.
26542097
Unable to get D-blade ID of destination.
26542101
Unable to contact the source node.
26542102
Unable to contact the destination node.
26542120
An SVM migrate operation is in progress. When the migrate operation completes, try the operation again.
26542121
A MetroCluster disaster recovery operation is in progress. When the recovery operation completes, try the operation again.
196608334
Failed to modify the aggregate because it contains NAE volumes.
196608335
Failed to modify the aggregate because it contains non-encrypted volumes.
string
added_data_disk_count
integer
Number of added data disks in RAID group.
added_parity_disk_count
integer
Number of added parity disks in RAID group.
existing_data_disk_count
integer
Number of existing data disks in the RAID group.
existing_parity_disk_count
integer
Number of existing parity disks in the RAID group.
is_partition
boolean
Indicates whether the disk is partitioned (true) or whole (false).
name
string
Name of the raid group.
usable_size
integer
Usable size of each disk, in bytes.
storage_pool_reference
Shared Storage Pool
name
string
uuid
string
storage_pools
allocation_units_count
integer
Allocation count of storage pool.
storage_pool
Shared Storage Pool
hybrid_cache
Contains the configuration for the hybrid cache. The hybrid cache is made up of either whole SSDs or storage pool SSDs.
disk_count
integer
Number of disks used in the cache tier of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
disk_type
string
Type of disk being used by the aggregate's cache tier.
enabled
boolean
Specifies whether the aggregate uses HDDs with SSDs as a cache.
raid_size
integer
Option to specify the maximum number of disks that can be included in a RAID group.
raid_type
string
RAID type for SSD cache of the aggregate. Only provided when hybrid_cache.enabled is 'true'.
array[simulated_raid_groups]
size
integer
Total usable space in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
storage_pools
array[storage_pools]
List of storage pool properties and allocation_units_count for aggregate.
used
integer
Space used in bytes of SSD cache. Only provided when hybrid_cache.enabled is 'true'.
mirror
enabled
boolean
Aggregate is SyncMirror protected
state
string
plex_reference
Plex
name
string
integer
integer
data_disk_count
integer
Number of data disks in RAID group.
integer
integer
is_partition
boolean
name
string
parity_disk_count
integer
Number of parity disks in RAID group.
raid_type
string
RAID type of the aggregate.
usable_size
integer
primary
Configuration information for the primary storage portion of the aggregate. This excludes the hybrid cache details.
disk_count
integer
Number of disks used in the aggregate. This includes parity disks, but excludes disks in the hybrid cache.
disk_type
string
The type of disk being used by the aggregate.
raid_size
integer
raid_type
string
block_storage
hybrid_cache
hybrid_cache
mirror
mirror
plexes
array[plex_reference]
Plex reference for each plex in the aggregate.
primary
primary
storage_type
string
Type of aggregate.
uses_partitions
boolean
If true, aggregate is using shared disks.
cloud_store
Cloud store
_links
_links
name
string
uuid
string
cloud_storage_tier
cloud_store
cloud_store
Cloud store
used
integer
Capacity used in bytes in the cloud store by this aggregate. This is a cached value calculated every 5 minutes.
cloud_storage
attach_eligible
boolean
Specifies whether the aggregate is eligible for a cloud store to be attached.
migrate_threshold
integer
Specifies the minimum percentage of performance tier free space that must exist in order for migration of data from the capacity tier to performance tier to be allowed. Only valid for PATCH operations.
stores
array[cloud_storage_tier]
Configuration information for each cloud storage portion of the aggregate.
tiering_fullness_threshold
integer
The percentage of space in the performance tier that must be used before data is tiered out to the cloud store. Only valid for PATCH operations.
data_encryption
drive_protection_enabled
boolean
Specifies whether the aggregate uses self-encrypting drives with data protection enabled.
software_encryption_enabled
boolean
Specifies whether NetApp aggregate encryption is enabled. All data in the aggregate is encrypted.
dr_home_node
name
string
uuid
string
home_node
_links
_links
name
string
uuid
string
enabled
boolean
Specifes whether or not inactive data reporting is enabled on the aggregate.
start_time
string
Timestamp at which inactive data reporting was enabled on the aggregate.
inode_attributes
file_private_capacity
integer
Number of files that can currently be stored on disk for system metadata files. This number will dynamically increase as more system files are created. This is an advanced property; there is an added computationl cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
file_public_capacity
integer
Number of files that can currently be stored on disk for user-visible files. This number will dynamically increase as more user-visible files are created. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
files_private_used
integer
Number of system metadata files used. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
files_total
integer
Maximum number of user-visible files that this referenced file system can currently hold. If the referenced file system is restricted or offline, a value of 0 is returned.
files_used
integer
Number of user-visible files used in the referenced file system. If the referenced file system is restricted or offline, a value of 0 is returned.
max_files_available
integer
The count of the maximum number of user-visible files currently allowable on the referenced file system.
max_files_possible
integer
The largest value to which the maxfiles-available parameter can be increased by reconfiguration, on the referenced file system.
max_files_used
integer
The number of user-visible files currently in use on the referenced file system.
used_percent
integer
The percentage of disk space currently in use based on user-visible file count on the referenced file system.
version
integer
The inofile-version of the aggregate. If the referenced file system is restricted or offline, a value of 0 is returned. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
other
integer
read
integer
total
integer
write
integer
metric
The most recent sample of I/O metrics for the aggregate.
_links
_links
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Errors associated with the sample. For example, if the aggregation of data over multiple nodes fails, then any partial errors might return "ok" on success or "error" on an internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
node
_links
_links
name
string
uuid
string
raid_group
default
integer
Default number of disks in a RAID group.
max
integer
Maximum number of disks allowed in a RAID group.
min
integer
Minimum number of disks allowed in a RAID group.
layout_requirement
aggregate_min_disks
integer
Minimum number of disks to create an aggregate.
default
boolean
Indicates if this RAID type is the default.
raid_group
raid_group
raid_type
string
RAID type.
node
Node where the spares are assigned.
_links
_links
name
string
uuid
string
aggregate_spare
checksum_style
string
The checksum type that has been assigned to the spares.
disk_class
string
Disk class of spares.
disk_type
string
Type of disk.
is_partition
boolean
Indicates whether a disk is partitioned (true) or whole (false)
layout_requirements
array[layout_requirement]
Available RAID protections and their restrictions.
node
node
size
integer
Usable size of each spare, in bytes.
syncmirror_pool
string
SyncMirror spare pool.
total
integer
Total number of spares in the bucket. The total spare count for each class of spares also includes reserved spare capacity recommended by ONTAP best practices.
  • example: 10
  • readOnly: 1
  • Introduced in: 9.11
usable
integer
Total number of usable spares in the bucket. The usable count for each class of spares does not include reserved spare capacity recommended by ONTAP best practices.
  • example: 9
  • readOnly: 1
  • Introduced in: 9.6
snapshot
files_total
integer
Total files allowed in Snapshot copies
files_used
integer
Total files created in Snapshot copies
max_files_available
integer
Maximum files available for Snapshot copies
max_files_used
integer
Files in use by Snapshot copies
block_storage
aggregate_metadata
integer
Space used by different metafiles and internal operations inside the aggregate, in bytes.
integer
Aggregate metadata as a percentage.
available
integer
Space available in bytes.
integer
Amount of compacted data in bytes.
integer
Space saved in bytes by compacting the data.
integer
Percentage saved by compacting the data.
integer
The aggregate used percentage at which 'monitor.volume.full' EMS is generated.
inactive_user_data
integer
The size that is physically used in the block storage and has a cold temperature, in bytes. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data or **.
integer
The percentage of inactive user data in the block storage. This property is only supported if the aggregate is either attached to a cloud store or can be attached to a cloud store. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either block_storage.inactive_user_data_percent or **.
physical_used
integer
Total physical used size of an aggregate in bytes.
integer
Physical used percentage.
size
integer
Total usable space in bytes, not including WAFL reserve and aggregate Snapshot copy reserve.
used
integer
Space used or reserved in bytes. Includes volume guarantees and aggregate metadata.
integer
Total used including the Snapshot copy reserve, in bytes.
integer
Total used including the Snapshot reserve as a percentage.
integer
Amount of shared bytes counted by storage efficiency.
integer
Amount of space saved in bytes by storage efficiency.
integer
Percentage of space saved by storage efficiency.
integer
A summation of volume footprints inside the aggregate, as a percentage. A volume's footprint is the amount of space being used for the volume in the aggregate.
cloud_storage
used
integer
Used space in bytes in the cloud store. Only applicable for aggregates with a cloud store tier.
efficiency
Storage efficiency.
auto_adaptive_compression_savings
boolean
Indicates whether or not aggregate has auto adaptive compression savings.
cross_volume_background_dedupe
boolean
Indicates whether or not cross volume background deduplication is enabled.
cross_volume_dedupe_savings
boolean
Indicates whether or not aggregate has cross volume deduplication savings.
cross_volume_inline_dedupe
boolean
Indicates whether or not cross volume inline deduplication is enabled.
logical_used
integer
Logical used
ratio
number
Data reduction ratio (logical_used / used)
savings
integer
Space saved by storage efficiencies (logical_used - used)
Storage efficiency that does not include the savings provided by Snapshot copies.
logical_used
integer
Logical used
ratio
number
savings
integer
Storage efficiency that does not include the savings provided by Snapshot copies and Flexclone volumes.
logical_used
integer
Logical used
ratio
number
savings
integer
snapshot
available
integer
Available space for Snapshot copies in bytes
reserve_percent
integer
Percentage of space reserved for Snapshot copies
total
integer
Total space for Snapshot copies in bytes
used
integer
Space used by Snapshot copies in bytes
used_percent
integer
Percentage of disk space used by Snapshot copies
space
block_storage
block_storage
cloud_storage
cloud_storage
efficiency
efficiency
Storage efficiency.
footprint
integer
A summation of volume footprints (including volume guarantees), in bytes. This includes all of the volume footprints in the block_storage tier and the cloud_storage tier. This is an advanced property; there is an added computational cost to retrieving its value. The field is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter containing either footprint or **.
snapshot
snapshot
iops_raw
The number of I/O operations observed at the storage object. This can be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This can be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This can be used along with delta time to calculate the rate of throughput bytes per unit of time.
other
integer
read
integer
total
integer
write
integer
statistics
The real time I/O statistics for the aggregate.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
throughput_raw
throughput_raw
timestamp
string
aggregate
_links
_links
block_storage
block_storage
cloud_storage
cloud_storage
create_time
string
data_encryption
data_encryption
dr_home_node
dr_home_node
home_node
home_node
is_spare_low
boolean
name
string
Aggregate name.
node
node
sidl_enabled
boolean
snapshot
snapshot
space
space
state
string
uuid
string
Aggregate UUID.
volume-count
integer
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
action
arguments
array[string]
Arguments present in the specified action message.
code
integer
Corrective action code of the specified action.
message
string
Specifies the corrective action to be taken to resolve the issue.
warning
arguments
array[string]
Arguments present in the warning message encountered.
code
integer
Warning code of the warning encountered.
message
string
Details of the warning encountered by the aggregate simulate query.
aggregate_warning
action
action
name
string
Name of the entity that returns the warning.
warning
warning
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
