Update a file clone token
Updates a file clone token to modify its expiry time, ensuring the token remains valid for the intended duration of your operations.
HTTP method and endpoint
PATCH /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced in
ONTAP 9.10
Related Ontap commands
volume file clone token modify
Modify clone token
Use the PATCH API to update the expiry time associated with the clone token.
# The call:
curl -X PATCH "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae" -d '{"expiry_time": {"limit": "5400"} }'
# The response for successful PATCH is empty.
Learn More
DOC /storage/file/clone]
node.uuid |
string |
path |
True |
Node UUID |
uuid |
string |
path |
True |
Token UUID |
Request Body
| Name | Type | Description |
expiry_time |
node |
uuid |
string |
Token UUID. |
Status: 200, Ok
Status: Default, Error
href |
string |
self_link
expiry_time
left |
string |
Specifies the time remaining before the given token expires in ISO-8601 format. |
limit |
string |
Specifies when the given token expires in ISO-8601 format. |
_links
node_reference
name |
string |
uuid |
string |
token
token
expiry_time |
node |
uuid |
string |
Token UUID. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
