REST API reference
Update a file clone token
Updates a file clone token to modify the expiry time associated with it. This helps manage the lifecycle of file clones efficiently.
HTTP method and endpoint
PATCH /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced in
ONTAP 9.10
  • volume file clone token modify
Modify clone token
Use the PATCH API to update the expiry time associated with the clone token.<br>
# The call:
curl -X PATCH "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae" -d '{"expiry_time": {"limit": "5400"} }'
# The response for successful PATCH is empty.
Learn More
  • [DOC /storage/file/clone]
node.uuid
string
path
True
Node UUID
uuid
string
path
True
Token UUID
Request Body
Name Type Description
expiry_time
expiry_time
node
node_reference
uuid
string
Token UUID.
Status: 200, Ok
Status: Default, Error
string
expiry_time
left
string
Specifies the time remaining before the given token expires in ISO-8601 format.
limit
string
Specifies when the given token expires in ISO-8601 format.
node_reference
name
string
uuid
string
token
token
expiry_time
expiry_time
node
node_reference
uuid
string
Token UUID.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
