Update a file clone token
Updates a file clone token to modify attributes like the expiry time associated with the token. This action allows you to manage the lifecycle of file clones effectively.
HTTP method and endpoint
PATCH /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced in
ONTAP 9.10
Related Ontap commands
volume file clone token modify
Modify clone token
Use the PATCH API to update the expiry time associated with the clone token.<br>
# The call:
curl -X PATCH "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae" -d '{"expiry_time": {"limit": "5400"} }'
# The response for successful PATCH is empty.
Learn More
DOC /storage/file/clone]
node.uuid |
string |
path |
True |
Node UUID |
uuid |
string |
path |
True |
Token UUID |
Request Body
| Name | Type | Description |
expiry_time |
node |
uuid |
string |
Token UUID. |
Status: 200, Ok
Status: Default, Error
href |
string |
self_link
expiry_time
left |
string |
Specifies the time remaining before the given token expires in ISO-8601 format. |
limit |
string |
Specifies when the given token expires in ISO-8601 format. |
_links
node_reference
name |
string |
uuid |
string |
token
token
expiry_time |
node |
uuid |
string |
Token UUID. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
