REST API reference
Update a file clone token
PATCH /storage/file/clone/tokens/{node.uuid}/{uuid}
Introduced In: 9.10
Updates a file clone token.
  • volume file clone token modify
Modify clone token
Use the PATCH API to update the expiry time associated with the clone token.<br>
# The call:
curl -X PATCH "https://<mgmt_ip>/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca/905c42ce-a74b-11eb-bd86-0050568ec7ae" -d '{"expiry_time": {"limit": "5400"} }'
# The response for successful PATCH is empty.
Learn More
  • [DOC /storage/file/clone]
node.uuid
string
path
True
Node UUID
uuid
string
path
True
Token UUID
Request Body
Name Type Description
expiry_time
expiry_time
uuid
string
Token UUID.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
13565958
Failed to get information about token uuid for node node.name.
13565960
Failed to modify token expiry limit for node node.name.
string
expiry_time
left
string
Specifies the time remaining before the given token expires in ISO-8601 format.
limit
string
Specifies when the given token expires in ISO-8601 format.
node
name
string
Node name
uuid
string
Node UUID
token
token
expiry_time
expiry_time
uuid
string
Token UUID.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
