Updates the current enabled status of the automatic update feature and accepts the eula
PATCH /support/auto-update
Introduced In: 9.10
Updates the current enabled status of the automatic update feature and accepts the EULA.
Request Body
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262179 |
Unexpected argument. |
131072216 |
Automatic update requires AutoSupport to be enabled. |
131072217 |
Automatic update requires AutoSupport OnDemand to be enabled. |
131072218 |
Automatic update requires AutoSupport to use the HTTPS transport. |
| Name | Type | Description |
href |
string |
self
_links
eula
accepted |
boolean |
Flag indicating the End User License Agreement (EULA) acceptance. When the feature is enabled, it is assumed that the EULA is accepted. |
accepted_ip_address |
string |
IP Address from where the EULA was accepted. |
accepted_timestamp |
string |
Date and time when the EULA was accepted. |
user_id_accepted |
string |
User ID that provided the EULA acceptance. |
auto_update_info
_links |
enabled |
boolean |
Flag indicating feature state. |
eula |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
