REST API reference
Update the current enabled status of an automatic update feature
Updates the enabled status of the automatic update feature to reflect any changes. This is useful when you need to manage update settings and ensure compliance with the EULA.
HTTP method and endpoint
PATCH /support/auto-update
Introduced in
ONTAP 9.10
Usage notes
Updates the current enabled status of the automatic update feature and accepts the EULA.
Request Body
Name Type Description
_links
_links
enabled
boolean
Flag indicating feature state.
eula
eula
Example request
  "enabled": 1,
  "eula": {
    "accepted": 1,
    "accepted_ip_address": "192.168.1.125",
    "accepted_timestamp": "2020-12-01 08:12:23 -0500",
    "user_id_accepted": "admin"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262179
Unexpected argument.
131072216
Automatic update requires AutoSupport to be enabled.
131072217
Automatic update requires AutoSupport OnDemand to be enabled.
131072218
Automatic update requires AutoSupport to use the HTTPS transport.
string
self
eula
accepted
boolean
Flag indicating the End User License Agreement (EULA) acceptance. When the feature is enabled, it is assumed that the EULA is accepted.
accepted_ip_address
string
IP Address from where the EULA was accepted.
accepted_timestamp
string
Date and time when the EULA was accepted.
user_id_accepted
string
User ID that provided the EULA acceptance.
auto_update_info
_links
_links
enabled
boolean
eula
eula
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
