Update the current enabled status of an automatic update feature
PATCH /support/auto-update
Introduced In: 9.10
Updates the current enabled status of the automatic update feature and accepts the EULA.
Request Body
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262179  |
Unexpected argument.  |
131072216  |
Automatic update requires AutoSupport to be enabled.  |
131072217  |
Automatic update requires AutoSupport OnDemand to be enabled.  |
131072218  |
Automatic update requires AutoSupport to use the HTTPS transport.  |
| Name | Type | Description |
href  |
string  |
self
_links
self  |
eula
accepted  |
boolean  |
Flag indicating the End User License Agreement (EULA) acceptance. When the feature is enabled, it is assumed that the EULA is accepted.  |
accepted_ip_address  |
string  |
IP Address from where the EULA was accepted.  |
accepted_timestamp  |
string  |
Date and time when the EULA was accepted.  |
user_id_accepted  |
string  |
User ID that provided the EULA acceptance.  |
auto_update_info
_links  |
enabled  |
boolean  |
Flag indicating feature state.  |
eula  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
