Update the current enabled status of an automatic update feature
Updates the enabled status of the automatic update feature, ensuring it reflects your current preferences and compliance with the EULA.
HTTP method and endpoint
PATCH /support/auto-update
Introduced in
ONTAP 9.10
Usage notes
Updates the current enabled status of the automatic update feature and accepts the EULA.
force |
boolean |
query |
False |
Set the force flag to true to enable the automatic update feature regardless of how AutoSupport is configured. Without this flag set to true, an attempt to enable the automatic update feature fails unless AutoSupport is enabled, its transport is HTTPS, and the AutoSupport OnDemand feature is enabled.
Request Body
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262179 |
Unexpected argument. |
131072216 |
Automatic update requires AutoSupport to be enabled. |
131072217 |
Automatic update requires AutoSupport OnDemand to be enabled. |
131072218 |
Automatic update requires AutoSupport to use the HTTPS transport. |
131072219 |
The provided parameter requires an effective cluster version of ONTAP 9.16.1 or later. |
| Name | Type | Description |
href |
string |
self
_links
eula
accepted |
boolean |
Flag indicating the End User License Agreement (EULA) acceptance. When the feature is enabled, it is assumed that the EULA is accepted. |
accepted_ip_address |
string |
IP Address from where the EULA was accepted. |
accepted_timestamp |
string |
Date and time when the EULA was accepted. |
user_id_accepted |
string |
User ID that provided the EULA acceptance. |
auto_update_info
_links |
enabled |
boolean |
Flag indicating feature state. |
eula |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
