REST API reference
Update EMS configuration
Updates the Event Management System (EMS) configuration to modify how events are handled and logged, ensuring that your system's event management aligns with your operational requirements.
HTTP method and endpoint
PATCH /support/ems
Introduced in
ONTAP 9.6
Usage notes
Updates the EMS configuration.
  • event config modify
Request Body
Name Type Description
mail_from
string
Mail from
mail_server
string
Mail server (SMTP)
proxy_password
string
Password for HTTP/HTTPS proxy
proxy_url
string
HTTP/HTTPS proxy URL
proxy_user
string
User name for HTTP/HTTPS proxy
pubsub_enabled
boolean
Is Publish/Subscribe Messaging Enabled?
Example request
  "mail_from": "administrator@mycompany.com",
  "mail_server": "mail@mycompany.com",
  "proxy_password": "password",
  "proxy_url": "https://proxyserver.mycompany.com",
  "proxy_user": "proxy_user",
  "pubsub_enabled": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983123
The validation of the mail server provided failed
983136
The proxy URL cannot contain a username or password
983137
The proxy URL provided is invalid
983139
The IPv6 proxy URL provided is invalid
983140
The proxy URL provided contains an invalid scheme. Supported scheme is 'http'
983160
The provided parameter requires an effective cluster version of ONTAP 9.9.1 or later
string
ems_config
mail_from
string
Mail from
mail_server
string
Mail server (SMTP)
proxy_password
string
proxy_url
string
proxy_user
string
pubsub_enabled
boolean
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
