Update an EMS configuration
PATCH /support/ems
Introduced In: 9.6
Updates the EMS configuration.
Related ONTAP commands
event config modify
Request Body
| Name | Type | Description |
mail_from |
string |
Mail from |
mail_server |
string |
Mail server (SMTP) |
mail_server_password |
string |
Password for Mail server (SMTP) |
mail_server_user |
string |
Username for Mail server (SMTP) |
proxy_password |
string |
Password for HTTP/HTTPS proxy |
proxy_url |
string |
HTTP/HTTPS proxy URL |
proxy_user |
string |
User name for HTTP/HTTPS proxy |
pubsub_enabled |
boolean |
Is Publish/Subscribe Messaging Enabled? |
Example request
"mail_from": "administrator@mycompany.com",
"mail_server": "mail.mycompany.com",
"mail_server_password": "password",
"mail_server_user": "user",
"proxy_password": "password",
"proxy_url": "https://proxyserver.mycompany.com",
"proxy_user": "proxy_user",
"pubsub_enabled": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983123 |
The validation of the mail server provided failed |
983137 |
The proxy URL provided is invalid |
983139 |
The IPv6 proxy URL provided is invalid |
983140 |
The proxy URL provided contains an invalid scheme. The only supported scheme is 'http' |
983160 |
The provided parameter requires an effective cluster version of ONTAP 9.9.1 or later |
983220 |
The proxy URL provided contains an invalid scheme. The only supported schemes are 'http' and 'https' |
983224 |
The mail server URL cannot contain a username or password |
983225 |
The mail server username cannot be set without a mail server URL |
983226 |
The mail server password cannot be set without a mail server username |
983227 |
The provided field requires an effective cluster version of ONTAP 9.15.1 or later |
983229 |
The proxy URL cannot contain a username or password |
href |
string |
_links
ems_config
mail_from |
string |
Mail from |
mail_server |
string |
string |
mail_server_user |
string |
proxy_password |
string |
proxy_url |
string |
proxy_user |
string |
pubsub_enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
