Update an EMS configuration
Updates the Event Management System (EMS) configuration to modify how events are processed and logged. This allows you to tailor the configuration to meet specific monitoring and alerting needs.
HTTP method and endpoint
PATCH /support/ems
Introduced in
ONTAP 9.6
Usage notes
Updates the EMS configuration.
Related ONTAP commands
event config modify
Request Body
| Name | Type | Description |
mail_from |
string |
Mail from |
mail_server |
string |
Mail server (SMTP) |
mail_server_password |
string |
Password for Mail server (SMTP) |
mail_server_user |
string |
Username for Mail server (SMTP) |
proxy_password |
string |
Password for HTTP/HTTPS proxy |
proxy_url |
string |
HTTP/HTTPS proxy URL |
proxy_user |
string |
User name for HTTP/HTTPS proxy |
pubsub_enabled |
boolean |
Is Publish/Subscribe Messaging Enabled? |
Example request
"mail_from": "administrator@mycompany.com",
"mail_server": "mail.mycompany.com",
"mail_server_password": "password",
"mail_server_user": "user",
"proxy_password": "password",
"proxy_url": "https://proxyserver.mycompany.com",
"proxy_user": "proxy_user",
"pubsub_enabled": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983123 |
The validation of the mail server provided failed |
983136 |
The proxy URL cannot contain a username or password |
983137 |
The proxy URL provided is invalid |
983139 |
The IPv6 proxy URL provided is invalid |
983140 |
The proxy URL provided contains an invalid scheme. The only supported scheme is 'http' |
983160 |
The provided parameter requires an effective cluster version of ONTAP 9.9.1 or later |
983220 |
The proxy URL provided contains an invalid scheme. The only supported schemes are 'http' and 'https' |
983224 |
The mail server URL cannot contain a username or password |
983225 |
The mail server username cannot be set without a mail server URL |
983226 |
The mail server password cannot be set without a mail server username |
983227 |
The provided field requires an effective cluster version of ONTAP 9.15.1 or later |
href |
string |
_links
ems_config
mail_from |
string |
Mail from |
mail_server |
string |
string |
mail_server_user |
string |
proxy_password |
string |
proxy_url |
string |
proxy_user |
string |
pubsub_enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
