REST API reference
Update an EMS configuration
Updates the EMS configuration to modify event management settings according to your requirements.
HTTP method and endpoint
PATCH /support/ems
Introduced in
ONTAP 9.6
  • event config modify
Request Body
Name Type Description
mail_from
string
Mail from
mail_server
string
Mail server (SMTP)
mail_server_password
string
Password for Mail server (SMTP)
mail_server_user
string
Username for Mail server (SMTP)
proxy_password
string
Password for HTTP/HTTPS proxy
proxy_url
string
HTTP/HTTPS proxy URL
proxy_user
string
User name for HTTP/HTTPS proxy
pubsub_enabled
boolean
Is Publish/Subscribe Messaging Enabled?
Example request
  "mail_from": "administrator@mycompany.com",
  "mail_server": "mail.mycompany.com",
  "mail_server_password": "password",
  "mail_server_user": "user",
  "proxy_password": "password",
  "proxy_url": "https://proxyserver.mycompany.com",
  "proxy_user": "proxy_user",
  "pubsub_enabled": 1
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983123
The validation of the mail server provided failed
983137
The proxy URL provided is invalid
983139
The IPv6 proxy URL provided is invalid
983140
The proxy URL provided contains an invalid scheme. The only supported scheme is 'http'
983160
The provided parameter requires an effective cluster version of ONTAP 9.9.1 or later
983220
The proxy URL provided contains an invalid scheme. The only supported schemes are 'http' and 'https'
983224
The mail server URL cannot contain a username or password
983225
The mail server username cannot be set without a mail server URL
983226
The mail server password cannot be set without a mail server username
983227
The provided field requires an effective cluster version of ONTAP 9.15.1 or later
983229
The proxy URL cannot contain a username or password
string
ems_config
mail_from
string
Mail from
mail_server
string
Mail server (SMTP)
string
mail_server_user
string
proxy_password
string
proxy_url
string
proxy_user
string
pubsub_enabled
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
