REST API reference
Adds privileges to the specified local or active directory user or group and svm
required properties
  • svmuuid or svmname - existing svm for which privileges are added to user or group
  • name - exising local or active directory user or group for which privileges are to be added
  • privileges - list of privileges to be added to a user or group # related ontap commands
  • vserver cifs users-and-groups privilege add-privilege # learn more
  • [doc /protocols/cifs/users-and-groups/privileges](#docs-nas-protocols_cifs_users-and-groups_privileges)
POST /protocols/cifs/users-and-groups/privileges
Introduced In: 9.9
Adds privileges to the specified local or Active Directory user or group and SVM.
Important note
  • Specified privileges are appended to the existing list of privileges.
Required properties
  • svm.uuid or svm.name - Existing SVM for which privileges are added to user or group.
  • name - Exising local or Active Directory user or group for which privileges are to be added.
  • privileges - List of privileges to be added to a user or group.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
name
string
Local or Active Directory user or group name.
privileges
array[string]
An array of privileges associated with the local or Active Directory user or group. The available values are:
  • SeTcbPrivilege - Allows user to act as part of the operating system
  • SeBackupPrivilege - Allows user to back up files and directories, overriding any ACLs
  • SeRestorePrivilege - Allows user to restore files and directories, overriding any ACLs
  • SeTakeOwnershipPrivilege - Allows user to take ownership of files or other objects
  • SeSecurityPrivilege - Allows user to manage auditing and viewing/dumping/clearing the security log
  • SeChangeNotifyPrivilege - Allows user to bypass traverse checking
svm
svm
Example request
  "name": "user1",
  "privileges": [
    "string"
  "svm": {
    "name": "svm1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
655660
The operation is allowed only on data SVMs.
655673
Failed to resolve the user or group.
655730
The specified local user to which privileges are to be associated to does not exist.
string
svm
name
string
The name of the SVM.
uuid
string
user_group_privileges
name
string
privileges
array[string]
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
