REST API reference
Add privileges to a local, or Active Directory user or group and SVM
Adds privileges to a specified local or Active Directory user or group within an SVM. This operation is useful for expanding access permissions as needed.
HTTP method and endpoint
POST /protocols/cifs/users-and-groups/privileges
Introduced in
ONTAP 9.10
Usage notes
Adds privileges to the specified local or Active Directory user or group and SVM.
Important note
  • Specified privileges are appended to the existing list of privileges.
Required properties
  • svm.uuid or svm.name - Existing SVM for which privileges are added to user or group.
  • name - Exising local or Active Directory user or group for which privileges are to be added.
  • privileges - List of privileges to be added to a user or group.
  • vserver cifs users-and-groups privilege add-privilege
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
name
string
Local or Active Directory user or group name.
privileges
array[string]
An array of privileges associated with the local or Active Directory user or group. The available values are:
  • SeTcbPrivilege - Allows user to act as part of the operating system
  • SeBackupPrivilege - Allows user to back up files and directories, overriding any ACLs
  • SeRestorePrivilege - Allows user to restore files and directories, overriding any ACLs
  • SeTakeOwnershipPrivilege - Allows user to take ownership of files or other objects
  • SeSecurityPrivilege - Allows user to manage auditing and viewing/dumping/clearing the security log
  • SeChangeNotifyPrivilege - Allows user to bypass traverse checking
svm
svm
Example request
  "name": "user1",
  "privileges": [
    "string"
  "svm": {
    "name": "svm1",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
655660
The operation is allowed only on data SVMs.
655673
Failed to resolve the user or group.
655730
The specified local user to which privileges are to be associated to does not exist.
string
svm
name
string
The name of the SVM.
uuid
string
user_group_privileges
name
string
privileges
array[string]
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
