Add privileges to a local, or Active Directory user or group and SVM
Adds privileges to a specified local or Active Directory user or group within a Storage Virtual Machine (SVM). This operation is useful for managing user permissions efficiently by appending new privileges to an existing list.
HTTP method and endpoint
POST /protocols/cifs/users-and-groups/privileges
Introduced in
ONTAP 9.10
Usage notes
Adds privileges to the specified local or Active Directory user or group and SVM.
Important note
Specified privileges are appended to the existing list of privileges.
Required properties
svm.uuidorsvm.name- Existing SVM for which privileges are added to user or group. -
name- Existing local or Active Directory user or group for which privileges are to be added. -
privileges- List of privileges to be added to a user or group.
Related ONTAP commands
vserver cifs users-and-groups privilege add-privilege
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
name |
string |
Local or Active Directory user or group name. |
privileges |
array[string] |
An array of privileges associated with the local or Active Directory user or group. The available values are:
svm |
Example request
"name": "user1",
"privileges": [
"string"
"svm": {
"name": "svm1",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655660 |
The operation is allowed only on data SVMs. |
655673 |
Failed to resolve the user or group. |
655730 |
The specified local user to which privileges are to be associated to does not exist. |
href |
string |
_links
svm
name |
string |
uuid |
string |
user_group_privileges
name |
string |
privileges |
array[string] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
