Add privileges to a local, or Active Directory user or group and SVM
POST /protocols/cifs/users-and-groups/privileges
Introduced In: 9.9
Adds privileges to the specified local or Active Directory user or group and SVM.
Important note
Specified privileges are appended to the existing list of privileges.
Required properties
svm.uuidorsvm.name- Existing SVM for which privileges are added to user or group. -
name- Exising local or Active Directory user or group for which privileges are to be added. -
privileges- List of privileges to be added to a user or group.
Related ONTAP commands
vserver cifs users-and-groups privilege add-privilege
return_records  |
boolean  |
query  |
False  |
Request Body
| Name | Type | Description |
name  |
string  |
Local or Active Directory user or group name.  |
privileges  |
array[string]  |
An array of privileges associated with the local or Active Directory user or group. The available values are:
svm  |
Example request
  "name": "user1",
  "privileges": [
    "string"
  "svm": {
    "name": "svm1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655660  |
The operation is allowed only on data SVMs.  |
655673  |
Failed to resolve the user or group.  |
655730  |
The specified local user to which privileges are to be associated to does not exist.  |
href  |
string  |
_links
svm
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
user_group_privileges
name  |
string  |
privileges  |
array[string]  |
svm  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
