REST API reference
Configure a data SVM as a proxy
Configures a data SVM as a proxy to facilitate Active Directory-based authentication for cluster user accounts. This setup is typically used to streamline user account management within the cluster.
HTTP method and endpoint
POST /security/authentication/cluster/ad-proxy
Introduced in
ONTAP 9.7
Usage notes
Configures a data SVM as a proxy for Active Directory based authentication for cluster user accounts.
Required properties
  • svm.name or svm.uuid - Name and UUID of the SVM for a cluster user account.
  • security login domain-tunnel create
Request Body
Name Type Description
svm
svm
Example request
  "svm": {
    "name": "svm1",
Status: 201, Created
Status: Default, Error
string
svm
name
string
The name of the SVM.
uuid
string
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
