Configure a data SVM as a proxy
Configures a data SVM as a proxy for Active Directory authentication, allowing cluster user accounts to authenticate through Active Directory. This setup is essential when integrating ONTAP with Active Directory to manage user access centrally.
HTTP method and endpoint
POST /security/authentication/cluster/ad-proxy
Introduced in
ONTAP 9.7
Usage notes
Configures a data SVM as a proxy for Active Directory based authentication for cluster user accounts.
Required properties
svm.nameorsvm.uuid- Name and UUID of the SVM for a cluster user account.
Related ONTAP commands
security login domain-tunnel create
Request Body
| Name | Type | Description |
svm |
Example request
"svm": {
"name": "svm1",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621516 |
This operation is only supported on a data SVM. |
2621706 |
The specified |
href |
string |
_links
svm
name |
string |
uuid |
string |
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
