Configure a data SVM as a proxy
Configures a data SVM to act as a proxy for Active Directory-based authentication for cluster user accounts. This setup helps streamline authentication processes for managing cluster access.
HTTP method and endpoint
POST /security/authentication/cluster/ad-proxy
Introduced in
ONTAP 9.7
Usage notes
Configures a data SVM as a proxy for Active Directory based authentication for cluster user accounts.
Required properties
svm.nameorsvm.uuid- Name and UUID of the SVM for a cluster user account.
Related ONTAP commands
security login domain-tunnel create
Request Body
Status: 201, Created
Status: Default, Error
| Name | Type | Description |
href |
string |
_links
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
_links |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
