REST API reference
Configure a data SVM as a proxy
Configures a data SVM as a proxy for Active Directory authentication, allowing cluster user accounts to authenticate through Active Directory. This setup is essential when integrating ONTAP with Active Directory to manage user access centrally.
HTTP method and endpoint
POST /security/authentication/cluster/ad-proxy
Introduced in
ONTAP 9.7
Usage notes
Configures a data SVM as a proxy for Active Directory based authentication for cluster user accounts.
Required properties
  • svm.name or svm.uuid - Name and UUID of the SVM for a cluster user account.
  • security login domain-tunnel create
Request Body
Name Type Description
svm
svm
Example request
  "svm": {
    "name": "svm1",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
2621516
This operation is only supported on a data SVM.
2621706
The specified svm.uuid and svm.name refer to different SVMs.
string
svm
name
string
uuid
string
cluster_ad_proxy
The SVM configured as proxy for Active Directory authentication of cluster accounts.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
