REST API reference
Restore the keys for an SVM from a Google Cloud KMS
Restores the keys for a Storage Virtual Machine (SVM) from a configured Google Cloud Key Management Service (KMS), ensuring your SVM's encryption keys are securely managed and accessible.
HTTP method and endpoint
POST /security/gcp-kms/{uuid}/restore
Introduced in
ONTAP 9.10
Usage notes
Restores the keys for an SVM from a configured Google Cloud KMS.
  • security key-manager external gcp restore
uuid
string
path
True
UUID of the existing Google Cloud KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65537721
The Google Cloud Key Management Service is not configured for the given SVM.
65537722
Failed to restore keys on the following SVMs.
Name Type Description
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
