REST API reference
Restores the keys for an svm from a configured google cloud kms
POST /security/gcp-kms/{uuid}/restore
Introduced In: 9.10
Restores the keys for an SVM from a configured Google Cloud KMS.
  • security key-manager external gcp restore
uuid
string
path
True
UUID of the existing Google Cloud KMS configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
65537544
Missing wrapped top-level internal key protection key (KEK) from internal database.
65537721
The Google Cloud Key Management Service is not configured for the given SVM.
65537722
Failed to restore keys on the following nodes.
Name Type Description
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
