Restore keys for an SVM from a Google Cloud KMS
POST /security/gcp-kms/{uuid}/restore
Introduced In: 9.10
Restores the keys for an SVM from a configured Google Cloud KMS.
Related ONTAP commands
security key-manager external gcp restore
uuid  |
string  |
path  |
True  |
UUID of the existing Google Cloud KMS configuration.  |
return_timeout  |
integer  |
query  |
False  |
return_records  |
boolean  |
query  |
False  |
Status: 202, Accepted
| Name | Type | Description |
job  |
  "job": {
    "uuid": "string"
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537544  |
Missing wrapped top-level internal key protection key (KEK) from internal database.  |
65537721  |
The Google Cloud Key Management Service is not configured for the given SVM.  |
65537722  |
Failed to restore keys on the following nodes.  |
href  |
string  |
_links
job_link
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
