Restore keys for an SVM from a Google Cloud KMS
Restores the keys for an SVM from a Google Cloud KMS when you need to recover or reinstate secure key management configurations.
HTTP method and endpoint
POST /security/gcp-kms/{uuid}/restore
Introduced in
ONTAP 9.10
Usage notes
Restores the keys for an SVM from a configured Google Cloud KMS.
Related ONTAP commands
security key-manager external gcp restore
uuid |
string |
path |
True |
UUID of the existing Google Cloud KMS configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537721 |
The Google Cloud Key Management Service is not configured for the given SVM. |
65537722 |
Failed to restore keys on the following SVMs. |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
