Create a new token to reserve the split load
Creates a token to reserve space for clone creation on a node, managing the clone split load effectively. Use this operation when you need to ensure sufficient space is allocated for clone processes, with options to specify reserve size and expiration parameters.
HTTP method and endpoint
POST /storage/file/clone/tokens
Introduced in
ONTAP 9.10
Usage notes
Creates a new token to reserve the split load.
Required Properties
node.uuid -
reserve-size
Optional Propeties
expiry_time.limit -
expiry_time.left
Related Ontap Commands
volume file clone token create
Learn More
DOC /storage/file/clone]
Creating clone tokens to reserve space for clone creation on the node
There is a limit on the amount of clone data that can undergo a split at a point of time on the node (clone split load). Clone tokens are used to reserve space from clone split load for clone creation. The POST operation is used to create clone tokens with reserve-size and expiry-time.limit in the body.<br>
# The API
/api/storage/file/clone/tokens
# The call
curl -X POST "https://<mgmt_ip>/api/storage/file/clone/tokens" -H "accept: application/hal+json" -d '{"node": {"uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca"}, "reserve_size": "40M", "expiry_time": { "limit": "4200"} }'
# The response
"num_records": 1,
"records": [
"node": {
"name": "node1"
"uuid": "286f6ae4-c94d-11eb-adb5-005056bbeb0b",
"reserve_size": 41943040,
"href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca"
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
expiry_time |
node |
reserve_size |
integer |
Specifies the available reserve in the file clone split load for the given token. |
uuid |
string |
Token UUID. |
Example request
"expiry_time": {
"left": "string",
"limit": "string"
"node": {
"name": "node1",
"reserve_size": 0,
"uuid": "string"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[token] |
"records": [
"expiry_time": {
"left": "string",
"limit": "string"
"node": {
"name": "node1",
"reserve_size": 0,
"uuid": "string"
Status: Default, Error
href |
string |
self_link
expiry_time
left |
string |
Specifies the time remaining before the given token expires in ISO-8601 format. |
limit |
string |
Specifies when the given token expires in ISO-8601 format. |
_links
node_reference
name |
string |
uuid |
string |
token
token
expiry_time |
node |
reserve_size |
integer |
uuid |
string |
Token UUID. |
collection_links
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
