REST API reference
Create a new token to reserve the split load
Creates a new token to reserve space for clone creation on a node. This operation helps manage the clone split load by allocating a specified reserve size and setting an expiry time limit.
HTTP method and endpoint
POST /storage/file/clone/tokens
Introduced in
ONTAP 9.10
Usage notes
Creates a new token to reserve the split load.
Required Properties
  • node.uuid
  • reserve-size
Optional Propeties
  • expiry_time.limit
  • expiry_time.left
  • volume file clone token create
Learn More
  • [DOC /storage/file/clone]
Creating clone tokens to reserve space for clone creation on the node
There is a limit on the amount of clone data that can undergo a split at a point of time on the node (clone split load). Clone tokens are used to reserve space from clone split load for clone creation. The POST operation is used to create clone tokens with reserve-size and expiry-time.limit in the body.<br>
# The API
/api/storage/file/clone/tokens
# The call
curl -X POST "https://<mgmt_ip>/api/storage/file/clone/tokens" -H "accept: application/hal+json" -d '{"node": {"uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca"}, "reserve_size": "40M", "expiry_time": { "limit": "4200"} }'
# The response
"num_records": 1,
"records": [
    "node": {
      "name": "node1"
    "uuid": "286f6ae4-c94d-11eb-adb5-005056bbeb0b",
    "reserve_size": 41943040,
        "href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca"
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
expiry_time
expiry_time
node
node_reference
reserve_size
integer
Specifies the available reserve in the file clone split load for the given token.
uuid
string
Token UUID.
Example request
  "expiry_time": {
    "left": "string",
    "limit": "string"
  "node": {
    "name": "node1",
  "reserve_size": 0,
  "uuid": "string"
Status: 201, Created
num_records
integer
Number of records.
records
array[token]
  "records": [
      "expiry_time": {
        "left": "string",
        "limit": "string"
      "node": {
        "name": "node1",
      "reserve_size": 0,
      "uuid": "string"
Status: Default, Error
string
expiry_time
left
string
Specifies the time remaining before the given token expires in ISO-8601 format.
limit
string
Specifies when the given token expires in ISO-8601 format.
node_reference
name
string
uuid
string
token
token
expiry_time
expiry_time
node
node_reference
reserve_size
integer
uuid
string
Token UUID.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
