REST API reference
Create a new token to reserve the split load
POST /storage/file/clone/tokens
Introduced In: 9.10
Creates a new token to reserve the split load.
Required Properties
  • node.uuid
  • reserve-size
Optional Properties
  • expiry_time.limit
Default values
  • expiry_time.limit - "60"
  • volume file clone token create
Learn More
  • [DOC /storage/file/clone]
Creating clone tokens to reserve space for clone creation on the node
There is a limit on the amount of clone data that can undergo a split at a point of time on the node (clone split load). Clone tokens are used to reserve space from clone split load for clone creation. The POST operation is used to create clone tokens with reserve-size and expiry-time.limit in the body.<br>
# The API
/api/storage/file/clone/tokens
# The call
curl -X POST "https://<mgmt_ip>/api/storage/file/clone/tokens" -H "accept: application/hal+json" -d '{"node": {"uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca"}, "reserve_size": "40M", "expiry_time": { "limit": "4200"} }'
# The response
"num_records": 1,
"records": [
    "node": {
      "uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca",
      "name": "node1"
    "uuid": "286f6ae4-c94d-11eb-adb5-005056bbeb0b",
    "reserve_size": 41943040,
    "expiry_time": {
      "limit": "PT1H10M"
        "href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca"
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
expiry_time
expiry_time
node
node
reserve_size
integer
Specifies the available reserve in the file clone split load for the given token. Also note that the minimum value for reserve size is 4KB and any value specified below 4KB will be rounded off to 4KB.
uuid
string
Token UUID.
Example request
  "expiry_time": {
    "left": "string",
    "limit": "string"
  "node": {
    "name": "string",
    "uuid": "string"
  "reserve_size": 0,
  "uuid": "string"
Status: 201, Created
num_records
integer
Number of records.
records
array[token]
  "num_records": 1,
  "records": [
      "expiry_time": {
        "left": "string",
        "limit": "string"
      "node": {
        "name": "string",
        "uuid": "string"
      "reserve_size": 0,
      "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
13565959
Failed to create token for node node.name.
13565964
Reserve size cannot be negative.
13565997
The node.uuid doesn't exist.
string
expiry_time
left
string
Specifies the time remaining before the given token expires in ISO-8601 format.
limit
string
Specifies when the given token expires in ISO-8601 format.
node
name
string
Node name
uuid
string
Node UUID
token
token
expiry_time
expiry_time
node
node
reserve_size
integer
uuid
string
Token UUID.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
