Create a new token to reserve the split load
Creates a clone token to reserve space from the clone split load for clone creation. This is typically used when you need to manage the allocation of resources for clone operations on a specific node.
HTTP method and endpoint
POST /storage/file/clone/tokens
Introduced in
ONTAP 9.10
Usage notes
Creates a new token to reserve the split load.
Required Properties
node.uuid -
reserve-size
Optional Properties
expiry_time.limit
Default values
expiry_time.limit- "60"
Related ONTAP Commands
volume file clone token create
Learn More
DOC /storage/file/clone]
Creating clone tokens to reserve space for clone creation on the node
There is a limit on the amount of clone data that can undergo a split at a point of time on the node (clone split load). Clone tokens are used to reserve space from clone split load for clone creation. The POST operation is used to create clone tokens with reserve-size and expiry-time.limit in the body.<br>
# The API
/api/storage/file/clone/tokens
# The call
curl -X POST "https://<mgmt_ip>/api/storage/file/clone/tokens" -H "accept: application/hal+json" -d '{"node": {"uuid": "97255711-a1ad-11eb-92b2-0050568eb2ca"}, "reserve_size": "40M", "expiry_time": { "limit": "4200"} }'
# The response
"num_records": 1,
"records": [
"node": {
"name": "node1"
"uuid": "286f6ae4-c94d-11eb-adb5-005056bbeb0b",
"reserve_size": 41943040,
"href": "/api/storage/file/clone/tokens/97255711-a1ad-11eb-92b2-0050568eb2ca"
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
expiry_time |
node |
reserve_size |
integer |
Specifies the available reserve in the file clone split load for the given token. Also note that the minimum value for reserve size is 4KB and any value specified below 4KB will be rounded off to 4KB. |
uuid |
string |
Token UUID. |
Example request
"expiry_time": {
"left": "string",
"limit": "string"
"node": {
"name": "string",
"uuid": "string"
"reserve_size": 0,
"uuid": "string"
Status: 201, Created
num_records |
integer |
Number of records. |
records |
array[token] |
"num_records": 1,
"records": [
"expiry_time": {
"left": "string",
"limit": "string"
"node": {
"name": "string",
"uuid": "string"
"reserve_size": 0,
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
13565959 |
Failed to create token for node |
13565964 |
Reserve size cannot be negative. |
href |
string |
self_link
expiry_time
left |
string |
Specifies the time remaining before the given token expires in ISO-8601 format. |
limit |
string |
Specifies when the given token expires in ISO-8601 format. |
node
name |
string |
Node name |
uuid |
string |
Node UUID |
token
token
expiry_time |
node |
reserve_size |
integer |
uuid |
string |
Token UUID. |
collection_links
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
