Initialize a SnapLock ComplianceClock
POST /storage/snaplock/compliance-clocks
Introduced In: 9.10
Initializes the SnapLock ComplianceClock.
Required properties
node.nameornode.uuid- Name or UUID of the node.
Related ONTAP commands
snaplock compliance-clock initialize
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
node |
time |
string |
Compliance clock time |
Example request
"node": {
"name": "node1",
"time": "2018-06-04T19:00:00Z"
Status: 201, Created
node |
time |
string |
"node": {
"name": "node1",
Status: Default, Error
href |
string |
_links
node
name |
string |
uuid |
string |
snaplock_compliance_clock
node |
time |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
