Initialize a SnapLock ComplianceClock
Initializes the SnapLock ComplianceClock on a node, setting the compliance clock for data governance and retention purposes.
HTTP method and endpoint
POST /storage/snaplock/compliance-clocks
Introduced in
ONTAP 9.10
Required properties
node.nameornode.uuid- Name or UUID of the node.
Related ONTAP commands
snaplock compliance-clock initialize
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
node |
time |
string |
Compliance clock time |
Example request
"node": {
"name": "node1",
"time": "2018-06-04 19:00:00 +0000"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response codes
| Error code | Description |
13763062 |
Compliance Clock already initialized |
13763084 |
ComplianceClock re-initialization failed as it requires that all nodes in the cluster are healthy, all volumes are in online state, no volumes are present in the volume recovery queue and there are no SnapLock volumes or volumes with "snapshot-locking-enabled" set to true or S3 buckets with object locking enabled. |
13763085 |
ComplianceClock re-initialization supported on effective cluster version of ONTAP 9.14.1 or later. |
14090240 |
Node with the specified UUID does not exist |
14090241 |
The specified node name and node UUID refer to different nodes |
14090343 |
Invalid field |
href |
string |
_links
node
name |
string |
uuid |
string |
snaplock_compliance_clock
node |
time |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
