REST API reference
Initialize a SnapLock ComplianceClock
POST /storage/snaplock/compliance-clocks
Introduced In: 9.10
Initializes the SnapLock ComplianceClock.
Required properties
  • node.name or node.uuid - Name or UUID of the node.
  • snaplock compliance-clock initialize
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
node
node
time
string
Compliance clock time
Example request
  "node": {
    "name": "node1",
  "time": "2018-06-04 15:00:00 -0400"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response codes
Error code Description
13763062
Compliance Clock already initialized
13763084
ComplianceClock re-initialization failed as it requires that all nodes in the cluster are healthy, all volumes are in online state, no volumes are present in the volume recovery queue and there are no SnapLock volumes or volumes with "snapshot-locking-enabled" set to true or S3 buckets with object locking enabled.
13763085
ComplianceClock re-initialization supported on effective cluster version of ONTAP 9.14.1 or later.
14090240
Node with the specified UUID does not exist
14090241
The specified node name and node UUID refer to different nodes
14090343
Invalid field
string
node
name
string
uuid
string
snaplock_compliance_clock
node
node
time
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
