REST API reference
Initialize a SnapLock ComplianceClock
Initialize the SnapLock ComplianceClock to set the initial compliance time on a node. This operation is essential for ensuring data retention policies are enforced correctly from the start.
HTTP method and endpoint
POST /storage/snaplock/compliance-clocks
Introduced in
ONTAP 9.10
Usage notes
Initializes the SnapLock ComplianceClock.
Required properties
  • node.name or node.uuid - Name or UUID of the node.
  • snaplock compliance-clock initialize
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
node
node
time
string
Compliance clock time
Example request
  "node": {
    "name": "node1",
  "time": "2018-06-04T19:00:00Z"
Status: 201, Created
node
node
time
string
  "node": {
    "name": "node1",
Status: Default, Error
string
node
name
string
uuid
string
snaplock_compliance_clock
node
node
time
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
