Delete an FC interface
Deletes an FC interface to remove it from your network configuration. This action is typically used when you need to decommission or replace an interface in your setup.
HTTP method and endpoint
DELETE /network/fc/interfaces/{uuid}
Introduced in
ONTAP 9.6
Related ONTAP commands
network interface delete
Learn more
uuid |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53280992 |
The FC interface could not be deleted because it is enabled. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
