Delete an FC interface
Removes an FC interface, typically when it is no longer needed or to reconfigure your network setup.
HTTP method and endpoint
DELETE /network/fc/interfaces/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes an FC interface.
Related ONTAP commands
network interface delete
Learn more
uuid |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53280992 |
The FC interface could not be deleted because it is enabled. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
