Delete an FC interface
Deletes a Fibre Channel (FC) interface when you need to remove it from the network configuration. Use this action when you are managing network interfaces and need to clean up or reconfigure your storage environment.
HTTP method and endpoint
DELETE /network/fc/interfaces/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes an FC interface.
Related ONTAP commands
network interface delete
Learn more
uuid |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53280992 |
The FC interface could not be deleted because it is enabled. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
