REST API reference
Delete an FC interface
Removes an FC interface from the network configuration. This operation is typically performed when an interface is no longer needed or requires replacement.
HTTP method and endpoint
DELETE /network/fc/interfaces/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Deletes an FC interface.
  • network interface delete
uuid
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
53280992
The FC interface could not be deleted because it is enabled.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
