Delete an S3 policy configuration
Deletes an S3 policy configuration for an SVM when you need to remove an existing policy setup.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.8
Usage notes
Deletes the S3 policy configuration of an SVM.
Related ONTAP commands
vserver object-store-server policy delete -
vserver object-store-server policy delete-statement
name |
string |
path |
True |
Policy name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
