Delete an S3 policy configuration
Deletes an S3 policy configuration for an SVM, typically when you need to remove outdated or unnecessary policies from your storage environment.
HTTP method and endpoint
DELETE /protocols/s3/services/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.8
Usage notes
Deletes the S3 policy configuration of an SVM.
Related ONTAP commands
vserver object-store-server policy delete -
vserver object-store-server policy delete-statement
name |
string |
path |
True |
Policy name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
