Delete an S3 policy configuration
DELETE /protocols/s3/services/{svm.uuid}/policies/{name}
Introduced In: 9.8
Deletes the S3 policy configuration of an SVM.
Related ONTAP commands
vserver object-store-server policy delete -
vserver object-store-server policy delete-statement
name |
string |
path |
True |
Policy name |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405858 |
Failed to "delete" the "policy" because the operation is only supported on data SVMs. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
